Oil & Fuel fuel injectors
   / fuel injectors #1
lippy
west central florida
yanmar 1510
need to know what everyone thinks is best and easy way to clean fuel injectors on tractor.
have a great day today and a better one tomorrow
   / fuel injectors #2
The easiest way is to put fuel injection cleaner in your diesel fuel. Use a little everytime you fill up.
   / fuel injectors #3
I've been looking at the injector cleaners in the stores. All I find seem to be for gas. Where can I fine a cleaner for diesel?
Larry
   / fuel injectors #4
I think if you read the fine print it will say for gas or diesel. Mine does, although I don't have it handy to give you a brand name.
   / fuel injectors #6
Might try a power service product...
Soundguy
   / fuel injectors #7
Now this may not be a good thing I did but , on my old Kubota , I replaced the fuel filter and in stead of filling it with fuel , I filled it with deisel conditioner(STP). Screwed it back on and started tractor. Ran a little rough for a while but once it ran out and started running on diesel again , it was ok. No ill effects. I'm not even sure if it did any good. Tractor runs smooth , although it did before the treatment. Might be worth a try ? /forums/images/graemlins/crazy.gif
   / fuel injectors
thank you all for the reply's ,will let you know how i make out
lippy
   / fuel injectors #9
stp is mostly 70% or more #1 diesel fuel as per a report in a magazine for over the road additives. The 3 top ones were powerservice howes and lucas.
walmart or pilot truckstop would have a brand.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
Landoll Hauloll (A53472)
Landoll Hauloll...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
