Oil & Fuel fuel guage
   / fuel guage #1
jdboy4410
Bronze Member
windsor,pa.
john deere 4410,1962 Gravely L model,Gravely Commercial 10,multiple attachments,and JD x320
did they ever come up with a fix for the 4 thousand ten series tractor fuel guages ? my fuel sender was replaced once under warranty and it still did'nt work properly.now,sometimes the guage does'nt even work.i had the fogging problem with the cluster as well,but when at the dealer,they said they could'nt duplicate it,they all had the issue,even the previous models.mine was never really bad,but it still does it.another problem they could'nt fix is an intermediate lunging.at times,especially when you are doing loader work where you are backing up and going forward frequently,you press the pedal to go forward and you have to push the pedal almost half way down to get it to move and it will lunge to that pedal position.it was worked on twice for this concern but was never fixed,and again,they could never duplicate it at the shop.it does it all the time now,i just anticipate it happening so i am carefull when in close proximity to objects.anyone else had the same issue's ?
   / fuel guage #2
I don"t know about the guage and cluster. Your tractor is a hydro Yes? if you want faster directional response you need to change the roll out. There is a button you can change from fast roll out for loader work to a slower roll out for mowing. The roll out is how fast the tractor stops mowing after you let up on the pedal. On the pre e-hydro tractors when you let off the pedal it would stop immediatly. If you let off too fast you would throw yourself out of the seat. Deere added a roll out feature to the e-hydro to prevent this. There is a procedure for setting the roll out to exactly how fast you want it to change directions. It is all in your manual.
   / fuel guage #3
They haven't on the 4X20 series! I'm on #4 and it still doesnt work correctly.
   / fuel guage #4
Not to high jack your thread, but what can one do about the fogging in the cluster?
My 4310 is doing that, is there a way to get the glass out and clean it?
Grundfos Centrifugal Pump (A50121)
Grundfos...
Cub Cadet Z-Force Zero Turn Mower (A50121)
Cub Cadet Z-Force...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
