Fuel Gelling and question on 911 ratios.
   / Fuel Gelling and question on 911 ratios. #1
Dr Dirt
Lebanon Maine
New Holland td 24
I have a small TD24 that has a nagging fuel gelling problem. Does anyone know if there is an internal fuel tank filter? I have had some water in the fuel filter bowl in the past and one theory is that there might actually be ice blocking or rolling around in the sump [ if any ]. This spring I am planning on removing the tank and cleaning it out. The big question is "How much is too much with either or Red or White Diesel 911. These tanks are only about 6 gallons. Thanks, Dan
   / Fuel Gelling and question on 911 ratios. #2
To remove water prevent fuel filter icing, Diesel 911 (red bottle) calls for 3.2 oz per 10 gallons. To reliquefy gelled fuel, it calls for 8 oz per 10 gallons. If you're using biodiesel up to a 20% blend, double those amounts. In a gelled filter, it calls for 1/2 911 and 1/2 diesel in the filter bowl. Lots easier to keep a couple spare $5 fuel filters handy.
Got some water in my fuel during the blizzard a couple of weeks ago. Stopped me dead in my tracks. Emptied the fuel filter bowl, it had some water in it. Replaced the fuel filter element, and also removed the inlet line to the filter. As I suspected, it also had some water in it. Drained about a pint or so from the line, put it all back together, bled the air at the injector pump, and it fired up. Got some red bottle Diesel 911 and dosed the fuel with 6 oz of that in my full 11 gallon tank, and also put in some Stanadyne blue. I had been using Power Service white bottle regularly, but it didn't prevent that water problem. I think part of that issue was that I had summer diesel in it, and only a half-tank, and perhaps some condensation occurred inside that black plastic tank.
It's been running perfect since, and we've had some -18 air/-40 wind chill nights where I ran the tractor to move snow. Sure glad I switched to synthetic oil on the last oil change.
Any of the suggestions from replies to your post of about a year ago with a similar issue able to help?
Thanks Grizz,
Now I am curious about your mention of synthetic oil.
I am still wondering how much is too much regarding the concentration of Diesel fuel additives.
BTW I do have several funny locomotive fuel stories and one hilarious Diesel fuel issue aboard a "Yawl" boat tugging an un-powered 135ft schooner in Boston Harbor 20 years ago!
When you pulled your tank, did you notice the configuration of the sump? I am wondering if I could get a small vacuum line to the bottom of the tank with a 5/16" suction tube?
Thanks Dan.
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
2020 VOLVO VNL SLEEPER (A52576)
2020 VOLVO VNL...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
