Fuel gauge rust
   / Fuel gauge rust #1
Bocephous
Gibson Township, PA
LS 4047H
I've been having some issues with my fuel gauge lately, so I took it apart yesterday. Upon pulling the apparatus from the tank I saw that the top two or three inches of metal were rusted. I sanded it down to the metal, cleaned it up with brake cleaner, and reinstalled. Just thought I'd pass this on as it is something not often checked.
   / Fuel gauge rust #2
Water in your diesel fuel? Keep your tank full?
Check your main fuel filter for water?
Sent from my iPad using TractorByNet
   / Fuel gauge rust
There shouldn't be. I have fuel delivered once a year and the container is under cover. Wouldn't water settle to the bottom of the tank? Rusted part was at the top, not covered by fuel.
I do usually keep my tank at or near full.
I plan to change the filter out today or tomorrow.
   / Fuel gauge rust #4
You can get moisture in a bulk tank just from high humidity air. Assume your tank is vented? Assume you have a filter on outlet of your tank?
There should be a petcock on bottom of your main fuel filter on tractor. Open it slightly and turn on key (don't start) which will start fuel pump and push out any water at bottom of filter.
Don't know how anything could rust in an environment of splashing diesel fuel?
Good luck!
   / Fuel gauge rust
Good luck!
Yes, tank is vented, and I have a particle filter on the outlet.
I'll try your idea before I change the filter.
There have been periods when I won't use the tractor for a two weeks or so. Not usually during the warmer months but in the winter, especially if there isn't significant snow to plow.
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2006 Volvo VNL (A52128)
2006 Volvo VNL...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
City of Lakeland (A51691)
City of Lakeland...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
