Oil & Fuel Fuel Gauge Problem on a L4400
   / Fuel Gauge Problem on a L4400 #1
FL4400
NE Florida
Kubota L4400
What do you think my fuel gauge is stuck on full while running, when you turn the key off it goes back down to empty and also when you unplug the wires from the float. I have tapped on the tank and around the float to see if it stuck nut I have not had avy sucess. Anyone think the sending you on the float is bad?
   / Fuel Gauge Problem on a L4400 #2
Yup sounds like a bad sending unit or stuck in the full position.
   / Fuel Gauge Problem on a L4400 #3
The fuel guage on my L4400 appears to be non-linear, that is, it stays above the full mark for about half the tank, then starts dropping. This is similar to the way auto gas guages used to be. You used to think you were getting great gas mileage then the guage started dropping precipitously. Nowadays car guages tick off the gallons, quite accurately. Don't know why the difference but the one Kubota supplies appears to be cheap old technology. All I can say it's better than the guage on my 8N:(take the cap off and look in the tank)
simonmeridew
   / Fuel Gauge Problem on a L4400 #4
Mine does the same thing too. When it gets to 1/2, you better think of filling it. I think the tank is shaped like a funnel, so the lower the fuel level, the faster the gauge drops..
   / Fuel Gauge Problem on a L4400 #5
Sure sounds like the sending unit. You still under warranty?
When I was looking for a tractor before I got my L4400 I was looking at a used Massey of some sort. There was a skiny stick hanging from a wire near the dashboard. I asked the dealer what it was.....you got it...the fuel gauge!
My warranty ran out in May but my gauge does not drop after a 1/2 a tank it has always come down slowly like a gauge should. Now it just shows a full tank when ever it is running. I guess I am going to have to pull the float out and see what is going on.
Thanks Todd that should help out alot.
   / Fuel Gauge Problem on a L4400 #9
Add one more to the ranks of the broken fuel gauge (always full). The good part is that this is the only problem so far.
   / Fuel Gauge Problem on a L4400 #10
N80 -- sounds familiar.
Several weeks ago I borrowed a neighbours tractor. A branch laying on the loader frame turned out to be a fuel gauge.:D :D
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
New Holland 1431 Discbine (A50515)
New Holland 1431...
RAINBOW 040 00-402 TI-12 50 HARD HOSE TRAVELER (A51243)
RAINBOW 040 00-402...
2005 TerraGator 8104 (A52128)
2005 TerraGator...
John Deere 825i Gator (A50514)
John Deere 825i...
