Oil & Fuel Fuel Gauge on 3720 Cab stopped working
   / Fuel Gauge on 3720 Cab stopped working #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
I was mowing yesterday and all of a sudden (Might have been at the same time I raised/lowered the 3pt hitch with the mower) the fuel gauge just dropped to E (From maybe 1/2) and the 'Low Fuel' warning light went on. I wasn't low on fuel. Just to check, I filled it up to the brim and the Gauge didn't budge.
The Gauge does come on during the power on self test (Goes up to F then back to E when all the lights come on when you first turn the key) so I'm sure it's the sender/connection to the sender and not the meter itself.
Anyone run into this and had it be something simple like a disconnected wiring connector or something? I looked high and low (without disassembling anything) and couldn't see where the sending unit or the wire to it is located. All I could see was the fuel and vent hose. I suspect disassembly is needed to gain access to these but if so I'll leave that to the dealer since it's still under warranty. I just want to make sure that if it could be
something easy to get at/simple that I check it first.
Also, I haven't checked my fuses but I can't imagine there is a separate fuse on the sender unit and everything else electrical seems to work.
Thanks in Advance.
   / Fuel Gauge on 3720 Cab stopped working #2
Sounds like wiring or a wiring issue. I am not familiar with the 3720 cab to know where to check the sender wiring. Maybe it got caught on something.
D.
20306 (A51694)
20306 (A51694)
2022 Doolittle 7712 - SS Trailer (A50514)
2022 Doolittle...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
