Oil & Fuel Fuel Gauge GC2310
   / Fuel Gauge GC2310 #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
Hi, My tractor's fuel gauge is stuck on full, it does go down when power is off, but normally shows full. Thanks for any advice. plowking
   / Fuel Gauge GC2310 #2
Could be either a faulty sending unit or wire to unit is grounding out. Try connecting a new wire from the gauge to sender, this will show up a short, if still shows full, problem with sender. HTH. JJ.
   / Fuel Gauge GC2310 #3
If your fuel tank is easily accessible just unhook the wire to the sending unit on the tank with the key on. If the gauge drops back to empty the problem is with the sending unit in the tank. If the gauge stays on full with the wire disconnected, the wire between the gauge and sender could be grounded.
   / Fuel Gauge GC2310
Thank you for the responces, I'll try it and see if sender is bad. My wife has since told me it never was accurate, at 1/4 tank on gauge, the tank was empty before it stopped working altogether. She keeps track of hour meter for now. plowking
   / Fuel Gauge GC2310
I haven't done anything about fuel guage, my wife has it on her list of things, the next time tractor goes back to dealer. plowking
(5) Roll up Doors (A50121)
(5) Roll up Doors...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
Firestone Tires (A50121)
Firestone Tires...
