Oil & Fuel Fuel Filters Keep Stopping Up in BX1850
   / Fuel Filters Keep Stopping Up in BX1850 #1
bmtolleson
I am about to change the fuel filters on my Kubota BX1850 for the third time in only 20 hours. The second time I changed them, I completely drained the tank and put fresh diesel in from a different supplier. I added SeaFoam as well. I noticed that the used filters were filled with a dark green to black gunk. I also have been using SeaFoam ever since. In only about 10 hours, the tractor is showing symptoms of the filters stopping up again. What must I do to keep from having to change the fuel filters every 10 hours?
   / Fuel Filters Keep Stopping Up in BX1850 #2
Maybe try using a fuel conditioner if you think the "gunk" might be diesel fungus. I get it here whenever fuel is stored a few weeks in warm weather.
   / Fuel Filters Keep Stopping Up in BX1850 #3
Ouch, the tank needs to be flushed. if biocide has been added, all the aglae stuff becomes black sludge and go to bottom of tank. Looks like you have a big job ahead of you to drain tank, clean sludge, flush out with petrol or alochol then hook up with clean filter. when getting new diesel, I would take the extra 5 mins to clean your can as well to be on the safe side.
   / Fuel Filters Keep Stopping Up in BX1850 #4
Sounds like a bad case of bacterial growth in the fuel system. You will need to treat the fuel with a biocide to kill them off, flush out the fuel tank and refill. Continue to treat with a biocide to prevent any further growth.
   / Fuel Filters Keep Stopping Up in BX1850 #5
I second bacteria. When this happens you'll change several filters before all the gunk works it way out of the tank.
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
UNUSED FUTURE MINI SKID STEER STUMP GRINDER (A51244)
UNUSED FUTURE MINI...
