Oil & Fuel Fuel Filter + Water
   / Fuel Filter + Water #1
Greyfields
I'm new to diesel engines. I noticed a bunch of fluid leaking from my engine. It looked watery but smelled like diesel. Investigating further, I figured out how to drain the fuel filter. I drained it into a mason jar. To me, it looked like all water came out (until it was dry). I started the engine up again, and then again drained another full quart jar of what looked like water but smelled like diesel. My fuel economy did seem to be sucking the last couple days.
Did I get a bad batch or diesel? Or, I did powerwash it about 3 days ago, is there a way for that water to get into the tank?
   / Fuel Filter + Water #2
You shouldn't have gotten any water into the fuels system or tank, unless you had the cap off. Probably a bad batch of diesel...
   / Fuel Filter + Water #3
If this is a continuing problem you can get a Mr. Funnel fuel filter funnel at Harbour Freight or West Marine. It will allow fuel to pass, but not water or debris. The one I have is about 3.9gpm and was $25, but there is also a bigger one that is 5gpm for about $40. I use to to fill my cans and then again to fill my tank. I got contamination in my tank once and that was enough.
   / Fuel Filter + Water #4
Diesel fuel is known for having water in it, hence the fuel/water seperators used to remove it. From the sounds of it your tractor had a rather excess amount in it. I would keep a eye on the fuel/water seperator and keep it drained. It would also be a good idea to run some fuel additive through it to help remove any water from the fuel tank.
   / Fuel Filter + Water #5
I would NEVER power wash an engine or the rest of the tractor. The gaskets just aren't designed to withstand that kind of pressure.
In over 200k miles of driving this Benz and about 60k of the other one, I've NEVER had a water problem. I carry a spare fuel filter in the trunk but have never had to use it, except for like today when I changed it out and put a new filter in the trunk.
Ralph
   / Fuel Filter + Water #6
I second the Mr Funnel recommendation...recently bought one and it works great:)
   / Fuel Filter + Water #7
Well we ran it last night. After about an hour, it started leaking again. It was definitely diesel it was leaking, not water. So, I have a new filter to pick-up today to see if that's the problem. My 'gas' mileage was really sucking recently, and I just thought it was because I was running the PTO hard with the tiller.
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
