Fuel Filter Symptoms
   / Fuel Filter Symptoms #1
gerard
Veteran Member
Syracuse NY
Kubota L2500DT w/FEL
Thought I'd share my recent fuel filter problem and save someone else some time. Last few days I started losing power while plowing up slight inclines in 6th gear. She'd just dog down and rpms would fall right off. (gear tractor with two ranges, chains on all 4 and loaded tire so lots of traction). This was something I never had a problem with before so I suspected either clogged injectors, bad injector, or fuel filter. Kubota dealer listened to my symptoms, asked if there were any black smoke when it dogged down (none), and said it sounded like a fuel filter.
Changed fuel filter according to directions, open bleed valve on top of filter housing until fuel runs clear, close, then open bleed valve on fuel pump for 30 seconds and close. Do all that and she won't start. No smoke, ie no fuel getting to pump. Pulled the small hose off the bleeder valve on the fuel pump that goes I don't know where and opened the valve. Fuel spurted a little, then ran steady. Should have been solid fuel since I had already cracked it for 30 seconds. Obviously maybe a blockage wherever it terminates so the air couldn't escape and I had an airlock. Put hose back on and she fired right up and no more dogging. Back to spinning wheels if the load gets too much!
Anway anyone experiencing simiar problems it's an easy do it yourself $15 fix. I'm also going to start changing fuel filters annually (every 100 hours) instead of the recommended 400 hours. Cheap enough insurance!
   / Fuel Filter Symptoms #2
Turn the old one upside down and see how much water you had captured.. It might surprise you. I was>>>Jy.
I'll have to try that and see if it was an issue. That was my first thought since it was when going up hills that I dogged down. I checked the tank with kolor kut, a water sensing paste and there was none in the tank but if the takeoff is at the bottom of the tank it water would collect in the bottom of the fuel fillter. Will have to check that with the paste.
   / Fuel Filter Symptoms #4
Mine was bogging at times last winter. Found a couple globs of what looked like wax near the fuel outlet line from the tank. I used a fish tool and grabbed them and removed. Refilled. Okay since.
This is after I'd replaced the fuel filter as first item of business.
That was my first use of off road diesel. I took it back and refilled with my normal on road stuff, which is B5. Don't save much buying off road here in Virginia.
Ralph
WANCO 6K LIGHT TOWER (A45046)
WANCO 6K LIGHT...
2017 VOLVO VNL630 TANDEM AXLE MID ROOF SLEEPER (A37762)
2017 VOLVO VNL630...
2020 Chevrolet Tahoe SUV (A42744)
2020 Chevrolet...
YANMAR VIO35-6A (A45333)
YANMAR VIO35-6A...
BUYERS PREMIUM ON EACH LOT # (A43003)
BUYERS PREMIUM ON...
30 Gallon Poly Chemical Inductor (A39855)
30 Gallon Poly...
