Oil & Fuel Fuel Filter for 555DTC
   / Fuel Filter for 555DTC #1
dginter
Demossville, KY
05' Farmtrac 555 DTC
I was wondering if anyone knew what kind of fuel filters are on the 555DTC?
was hoping to get part numbers with out having to take them off to find out.
Thanks!
   / Fuel Filter for 555DTC #2
I have a FT60 which was used till the mid '00s then became the 555.
I bought a spare fuel filter pack from my old Farmtrac dealer who still has some FT parts. It comes with two filters in the pack.
The Escorts of India pack part# is D10076780 fuel filter inserts. Date on pack is 1/2007 so I would say the filters are the same for the FT60 and 555.
Maybe Napa can cross reference from that number or someone may come up with another number shortly for after market filters.
   / Fuel Filter for 555DTC #3
ESL15354
ESL15357 are the two fuel filters/primary and secondary
I have tried it after market. You get only one of them which is used as a primary and secondary.
Try and get the originals
Sundowner Tractor for Farmtrac, Landtrac, Montana Tractor Parts
Authorized distributor for Farmtrac Parts, Tractors. Mahindra Parts.
Maybe Napa can cross reference from that number or someone may come up with another number shortly for after market filters.[/QUOTE]
   / Fuel Filter for 555DTC #4
I have a 545 and the best interchange I found is from Fleetguard which is sold by Cummins.
You are correct the FS1251 is the pre filter at 20 microns
and the FS19599 would be 6 microns.
NAPA and others interchange both of these to a 10 micron filter, which can work.
Tom
   / Fuel Filter for 555DTC #5
Here is what I have been using Baldwin BF587D, Sure filter 8422. I have used mostly the Baldwin filters. I think they are rated as secondary filters. I have a E mail into Baldwin for the Micron rating.
napa cross referenced them to a napa gold 3472 filter... got them changed out but havent actually used the tractor yet to see if they are restrictive..
   / Fuel Filter for 555DTC #7
Micron for Baldwin is 5 nominal and 20 absolute at 83% works for me. The napa 3472 is 10 nominal. You should be fine
23222 (A50323)
23222 (A50323)
2020 KUBOTA RTV...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
Case 830 Tractor (A50514)
Case 830 Tractor...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
78" Bucket (A47384)
78" Bucket (A47384)
