Fuel Filter Change question.
   / Fuel Filter Change question. #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Greetings smarter than me people. I have what may be a dumb question.. I have an Iseki TA247 3cyl close match to a massey 1240 if that helps. It had suddenly started to smoke a little when I would rev it a little. I have not changed fuel but someone told me it was likely the fuel filter. It's a little harder to start cold and seems like it lost a couple HP. The filter is in a plastic bowl with a an on/off and another position I cant read. My question is, If I remove the bowl will I have to re-bleed the fuel system? Or turn it off, change out filter and turn back on? I have not changed the filter in approx. 800 hrs.
Thank You !!
   / Fuel Filter Change question. #2
If you remove the fuel filter bowl, you normally will need to bleed the system. Even if you didn't have to, it would be a good idea to do it anyway as it is not that hard and eliminates possible other problems.
If it is smoking black, then you probably aren't fuel restricted (i.e. it's not your fuel filter). You might want to consider taking a look at the air filter and replacing it. I'd probably do both if each has over 800 hours of run time.
Thanks.
   / Fuel Filter Change question. #4
I would second that. Black smoke is usually caused by unburned fuel due to engine overload OR air filter stopped up. You are getting more fuel that the tractor can efficiently burn so I doubt your fuel filters are bad. If you can visually see that the fuel bowl doesn't have any water or sediment standing in it, then I wouldn't mess with the filters yet. IF you use clean fuel all the time, it may not need a new filter at all, HOWEVER, I have to agree that 800 hours is a long time between fuel filter changes.
I would get the air cleaner changed first to see if the black smoke goes away and then change out the fuel filter as a matter of course in preventative maintenance.
Thanks so much.. Getting an air filter today. I did keep it blown out, Sprayed it with solvent and blew it out again and let it dry. May not have been good enough. I'll see what a new one does.
New Air Filter fix'd the black smoke issue. I know the importance of the air filter but the one I took out was pretty clean. Maybe I damaged it by spraying it down with carb cleaner and blowing it off with the air hose or maybe the diesels are that fussy. In any event it's running perfect now with the new filter.
Thanks again for the assistance.
   / Fuel Filter Change question. #7
This is a very good reminder on fuel and air filters and the affects of dirty ones.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
5th Wheel Hitch (A50325)
5th Wheel Hitch...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
