Oil & Fuel Fuel Draining Generator
   / Fuel Draining Generator #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Thinking about 2 sets of these for my generator to allow removing the boat fuel tank for filling and draining and then the second male would allow the engine to run until the carb runs dry. Any opinions? Thanks.
http://i.ebayimg.com/images/g/-z4AAOSw9N1VoKVs/s-l400.jpg
HYspeed-Fuel-Gas-Line-Quick-Connect-Disconnect-5-16-Motorcycle-Dual-Shut-Off
US $10.99
eBay item number:
400955350319
   / Fuel Draining Generator #2
Many generators have a drain plug on the side of the fuel bowl. Usually a bolt with a sealing washer.
I like using this to drain the carb rather than running it dry as it help to allow any crud/water to run out keeping the bowl cleaner
On some generator engines the carb drain is a screw identified in photo by large red arrow and when screw is loosened fuel drains out where the small red arrow shows.
Dave M7040
Thanks for the reply Dave but my genset is ooold skool. Early 70's with no conveniences and needs 2 men and 4 small boys to lift it. But! Still earning his keep so I'm trying to make sure I don't drop the ball and screw it up.
   / Fuel Draining Generator #4
How about a make and model + some pictures
Dave M7040
2014 JLG G12-55A 12,000LB 4x4 Rough Terrain Telehandler (A50322)
2014 JLG G12-55A...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2020 KUBOTA RTV...
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2015 Takeuchi TW65 Series 2 (A47384)
2015 Takeuchi TW65...
