Fuel cut off solenoid problem?
   / Fuel cut off solenoid problem? #1
burnbridge
Tiverton, UK
Mitsubishi 180D
I have a Mitsubishi 180D. A couple of weeks ago when I pressed the engine stop button, nothing happened so I stopped it by closing the fuel tap. This happened a couple of times. Now the engine turns over but won't start. Looking at general advice online made be suspect the fuel cut off solenoid. The plunger does not move when the ignition is turned on, or when the engine is turning over, but if I connect the solenoid directly to the battery it moves inwards and stays there, and moves out again when disconnected. Grateful for any suggestions about what the problem is and how to fix.
   / Fuel cut off solenoid problem? #2
This is a complcating setup as I remember. It is tied into the oil pressure also. I have a service manual that covers it.
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
