fuel consumption
   / fuel consumption #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
I just bought a new ck30 hst with a front mount snow blower,It seems to use a lot of fuel compared to my old mf 1020 doing the same work
does any one know how many hours I can expect per tank of fuel
   / fuel consumption #2
Have you actually measured fuel consumed or are you just looking at the gauge? The gauges are famously inaccurate. I still have at least 5 gal remaining in my 15 gal tank when my DK45 reads empty. Diesel fuel consumption is pretty linear with shaft horsepower unless there is a problem in the engine (like a sick fuel injector).
   / fuel consumption #3
I have seen two estimates of diesel fuel consumption by tractors operating under "average" conditions: 0.044 and 0.048 gallons/hour/PTO HP. For 24 PTO HP, the estimated "average" fuel consumption would range between 1.06 and 1.15 gallons per hour.
Steve
   / fuel consumption #4
I have a 2004 (year built) CK30hst. I don't run a snowblower but when plowing with a backblade or using the fel to push piles of snow, my rpm is 2300-2400. At that engine speed, I use just under a gallon/hour. If I'm using the bh or lighter work and around 1800-2000rpm, I'm well below a gal/hour. This is a 1500cc or 91.5cu.in. 3 cylinder. I'm not sure what a MF 1020 had. Your tank is 7.9 gals. and you should definately get 8 hours. As mentioned, the fuel gauge isn't reliable for usage other than full and empty. When mine indicates a 1/4 tank, should be 2 gallons, I still have a little over 3. Mine did start do better though after the 50 hour mark and settled in at around 100 hours.
   / fuel consumption #5
Steve
I think that's pretty close. My tractor will burn right at or just under 1 gl./hr. running at PTO rpm and putting some torque load on the engine. Easy loader work and misc. light work goes to under 1/2 gl./hr. Over-all mixed use I have been averaging 5 gl. per 12 hrs. run time.
   / fuel consumption #6
That sounds about right. 1gal/hr. My CK27 uses about that when blowing snow.
1US gallon = 3.78Litres
   / fuel consumption #7
My new JD 1025 was using A LOT more fuel than my JD 4010. After about 20 hours, the fuel consumption has gone down to about hp prorate of that used by the 4010 over 660 hours: (24.2/18.5) x 0.46 gph = 0.6 gph. I keep the fuel used in a little notebook. Each time I finish off a 5 gallon container, I record the amount (5 gallons; sometimes it another amount) and the hours.
Ralph
1991 Ford L8000 (A50120)
1991 Ford L8000...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
Tracer Ultra Lite Camper (A50121)
Tracer Ultra Lite...
Craftsman LT2000 Riding Mower **Does Not Run** (A50121)
Craftsman LT2000...
