Fuel consumption CT450?
   / Fuel consumption CT450? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
Do you guys with CT450 go through alot of fuel? My machines seems to drink it like no tomorrow. I have a backhoe setup so i know the machines weights more to move around, But Im going through 4-gallon every 2 hours it seems. That is running almost full throttle and driving around and stopping and using backhoe. I do run an additive every few fill up's and don't know if that can kill the mpg. Also i have no fuel in the oil so its burning it up. Any idea's or is that normal?
   / Fuel consumption CT450? #2
Not a 450, but my 235 burns pretty much a gallon an hour.
   / Fuel consumption CT450? #3
The Daedong 4B243 has a published SFC (specific fuel consumption) of 192 g/hp-hr @ 2600 rpm.
That equates to 3.04 gal per hour when producing 50 hp @ 2600.
A consumption of 2 gallons per hour would represent an average engine output of 33 hp @ 2600 rpm.
   / Fuel consumption CT450? #4
My 225 @ 27 hp burns between .5 & .75 gl/hr. Usually running 2000 - 2300 rpm. but engine seldom if ever lugs and no BH to carry around. I am always working in low range, mid-range for getting from point A to B on the place or occasionly with rotary cutter in easy mowing conditions (high range works only for getting down the road). You have almost twice the HP as mine, probaboy work it harder so seems your fuel consumption is in line. Regrettably as the EPA continues to tighten up on exhaust emmisons the fuel consumption rate on these engines keeps climbing. Don't know why but the cleaner the fuel burn the more fuel engine consumes. Go figure!!!
Yup the EPA will kill diesel's off. I have a 2002 duramax which i use to pull my machine around. I will never give it up since it has no emission on it. Thats also why they get the best fuel MPG out of the duramax generation.
   / Fuel consumption CT450? #6
Agree that the government regulations to improve exhaust emissions continue to increase fuel consumption.
There needs to be a balance between the two.
Hopefully those that vote will someday demand politicians show the business case between all things. In this case, the further improvement in exhaust emissions vs the cost of equipment and the operating expenses we pay.
   / Fuel consumption CT450? #7
Milkman636
Do you have the SFC for the CT235?
Appreciate any help here.
   / Fuel consumption CT450? #8
My Kubota B3200 goes through roughly a gallon an hour at around 1800 RPMS with the BH attached.
   / Fuel consumption CT450? #9
my CT440 goes thru about a gallon an hour running hard and brush hogging. yours seems to be a bit excessive to me.
   / Fuel consumption CT450? #10
Milkman636
Attached is the engine performance curve for the 3A165 engine.
The SFC is 195g/hp-hr @ 2600
Your peak output of 34 hp @ 2600 would consume 2.1 gph, ironically right about where the OP is averaging with his CT450.
It looks like some of the information I saved from last year's tractor shopping might be useful after all.
  • 3A165_curve.pdf
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Test Button (A47384)
1996 Eager Beaver 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
