Fuel cap tight
   / Fuel cap tight #1
wilnis
Bronze Member
Hi-I have a TN60da, about 10 years old with about 210 hours on it. The plastic cap for the diesel tank has always fit tight to the point I can only turn it about 1-1/2 turns if I expect to get it off again. Any advise about how to lube it, petroleum jelly, dry lube, ???, new fuel cap?? The threads are not damaged on the lid or the tank in any way that I can tell, it's just tight. Any help appreciated. Thanks. Bill
   / Fuel cap tight #2
I'd use a little grease on the threads. I have the opposite problem on my tractor. My cap goes on easy but hard to get off to refill. Sometimes had to use large pliers to start it moving. I put grease on the threads and around the top to make it a little easier. Haven't had to use the pliers since. I know I'm getting older but not that old.
   / Fuel cap tight
George2615-Thanks for the reply, grease does seem a reasonable thing to use and I will give it a try. Bill
2006 CHEVROLET EXPRESS SERVICE VAN (A52577)
2006 CHEVROLET...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
Miles read : 112,969 (A50323)
Miles read ...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
