Oil & Fuel Fuel Bowl Assembly
   / Fuel Bowl Assembly #1
benkapitanec
On my MT180HD the fuel bowl has a 90 degree fitting for the fuel outlet that either has broken off or has worked it's way loose, I can't tell. Every now and then it will pop off and diesel will leak out. Anyone have this happen? Can this have a permanent fix or do I need to get a new or used fuel bowl?
   / Fuel Bowl Assembly #2
If the fitting is a press in fitting that is just slipping out of the hole, I would clean the hole and the fitting with brake clean and then just epoxy it back in with jb weld. The whole assembly on my Buck had been removed. I bought a new/used assembly that did not have the output hose fitting on it. I bought a pipe thread tap and a nylon 90 degree fitting and haven't had any problem since.
   / Fuel Bowl Assembly #3
I vote for Oliver's solution as well.
Cheap and easy, the bowl will be white metal or aluminum and tapping that will be real easy to do.
Do not use a brass fitting as the dissimilar metals will corrode real fast. (brass (copper) threaded into aluminum will set up an electrolitic raction and you will end up with a white corrosion mess)
Use nylon ar at worst steel fitting. Aluminum would also be OK.
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
