Oil & Fuel Fuel additive
   / Fuel additive #1
Jeff Saunders
Hot springs, Ar.
Kubota M7060
Should I add a diesel additive every time I fuel my tractor. I was told to add Lucus fuel additive by some friends that have tractors.
   / Fuel additive #2
I use Howes.
I put it in all my cans before I fill them. That way it's ready to go in the tractor when I need a fill up.
The Howes has worked well even in sub zero weather.
   / Fuel additive #3
I add Power Service in the white bottle with every fill up. I have no problems year round.
   / Fuel additive #5
I use Clean Flo most of the time, and make sure I add it if the tractor is going to sit. I use gas station fuel so it's fresh, if you have your own fuel tank I'd use it ever time.
   / Fuel additive #6
Use what you want any good additive works but lucas is what we use. just a bit every other tank is good. More is better but sometimes not necessary like when your running the tractor every day.
   / Fuel additive #7
I use Opti Lube in all my diesel engines.
   / Fuel additive #9
I add NOTHING to my fuel, ever... and I have NO fuel problems at all, same for my farmer neighbor, my brother and my other farmer friends...
I just don't understand all this "have to add" attitude on this site...
SR
   / Fuel additive #10
I had major issues last year and none this year with a record cold February. Minus 35 c some mornings. So if the fuel delivered is for winter service, (and my provider says there is a difference) gives you no grief, I see no point in adding anything for anti-gelling.
Now, providing lubrication for your injector pump in this day of ultra low sulpher diesel is another matter, and I try and add additive to my bulk tanks for this purpose. But, I have to say, I don't understand why it's not already put in there if it's a requirment of every Diesel engine? Would an engine meet EPA running fuel with additives, I wonder?
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
198846 (A51242)
198846 (A51242)
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
1967 Minneapolis- Moline M670 (A50514)
1967 Minneapolis-...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
