ft250a noisey transmission clutch out in neutral and all gears
   / ft250a noisey transmission clutch out in neutral and all gears #1
willard3
Old Town Fl.
rtv900
foton ft250 noisey transmission in neutral clutch disengaged and in all gears
   / ft250a noisey transmission clutch out in neutral and all gears #2
M'y FT254 had noise when clutch release ( like an old B & D drill when stopping) .
I had changed the clutch release bearing (even the old one was smooth).
I packed grease between main drive and PTO shafts and the thing I was gessing being the culprit was the clutch fingers (6) not adjusted equeal.
Did that four years (?) ago and all is fine until now.
Current hour on the tractor around 775h.
Jacques
Thank you for your reply, I will try that hope it works for me. willard
JOHN DEERE 8245R LOT IDENTIFIER 263 (A53084)
JOHN DEERE 8245R...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2019 CASCADE DM0B1300 HYD BALE CLAMP (A51247)
2019 CASCADE...
2016 R and R Products 331 LP Reel Mower (A51691)
2016 R and R...
