Frt loader bucket question.
   / Frt loader bucket question. #1
Lilguy
Chicago, Illinois
Kubota
My new 2601 has the quicktach 60 in light material bucket. It'll work great for gravel/earth/mulch bags and such.
The one thing it won't handle, I believe, is the Payne Forks I used on my old L2250. It obviously had a heavier pinded 60 in bucket which worked well with the pallet forks. Is there a heavier bucket available or should I just go for the quicktach Kubota forks.Thanks all.
   / Frt loader bucket question. #2
I'd go with forks myself.
   / Frt loader bucket question. #4
Don't know about that light material bucket, but the Payne forks have worked great on my standard bucket because of the add-on toothbar, which has provided enough reinforcement that the bucket has never bent, even under some extreme loads on the forks.
   / Frt loader bucket question. #5
I had a set of Payne forks on my old B7100. They would bend the bucket if I lifted something heavy. I bought a 60" piece of 3" x 1/4" thick angle iron and clamped it between the forks and the bucket cutting edge. That solved the problem by distributing the load evenly across the entire bucket width.
If money isn't an issue, you might do better with the QA forks. You will sacrifice a bit of reach but you'll get a little more lift since the forks are closer to the FEL pivot point.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
