Oil & Fuel Frt. axle hub luricant
   / Frt. axle hub luricant #1
Benzmender
Shibaura 2843T
Hi, i have a Shibaura 2843t [ Ford 1710 ] 4x4. Does anybody know what type of fluid the front axle Hub housing takes? Not the main axle but the gear reduction housings on each end where the wheels bolt on.I think its 80 or 90 weight but im not sure if it might take a special fluid and is there a specific amount to use or do you fill it to the bottom of the fill plug hole, like a car rear diff. I havent purched a manual yet and everything on the tractor is written in Japaneese. Thanks for any help!!!!!!
   / Frt. axle hub luricant #2
80/90 gear oil.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
Gleaner R50 Combine (A50514)
Gleaner R50...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
CATERPILLAR 926M WHEEL LOADER (A51242)
CATERPILLAR 926M...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
