Frozen Tire Fill Testing and Misc Tire Questions
   / Frozen Tire Fill Testing and Misc Tire Questions #1
rwinter
Nellysford, VA
JD 4720
I bought a tractor from Southern Georgia and now use it in Central Virginia. One day I awoke to find the tires frozen (had been down to 9 degrees that night; other nights, when going down to 14 degrees, they seemed OK the next day).
Anyway, when spring finally comes, I would like to test how cold it can be before the tires freeze again....I have no idea as to the fill that was used, but if it is alcohol, I would assume I can use a radiator tester and if it is calcium chloride or some salt based product, that I cannot, right? Any way to test the latter? Any way to figure out what kind of fill is in there now?
I am also wondering how to get more antifreeze goodies in....I know they have kits....with my backhoe arms, I am thinking I can raise the tires, remove the stems when the tire stem is in a high position, and then put in more fill...am I on track or do I have to rethink this?
Finally, and this seems like a really dumb question, but how can I tell if the tires have inner tubes or are tubeless? I am thinking they are tubeless because the stem is all metal and I figure I would see rubber if it was an inner tube. Is this right?
   / Frozen Tire Fill Testing and Misc Tire Questions #2
yes, no and maybee.
I've seen plenty of tubes that had a metal stem.
chances are if it froze solid.. it is not alcohol ( WW fluid ).
probbaly not cacl either.. or it would not have froze.. probbaly just water.
I'd add in some antifreeze and not fuss with it any more.
easy to slip a piece of fuel line over the stem after you remove the core, then use a pointy nose tipped bottle ( like comes on gear oil ) and then use that to add mix... just need enough to keep it from going solid... slushy is fine.
soundguy
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
HARDEE RD60M LOT NUMBER 157 (A53084)
HARDEE RD60M LOT...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2012 International 4300 Reefer Truck (A53472)
2012 International...
