Frozen Sprocket
   / Frozen Sprocket #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Hi Y'All,
Today I was cleaning my Stihl MS261, after using it for several hours a few days ago, when I found the sprocket on the 20 inch bar was "frozen". I could not turn it. Never have seen that before in many years and different saws????? I finally worked it loose and back to normal after some solvent and lots of twisting with a rag over the sprocket.
Anybody ever seen that? I was falling and limbing a couple 80 foot, long time dead, Pines.
Cheers,
Mike
   / Frozen Sprocket #2
Often happens when "noodling" rounds, as the long-strand fibers that come off the chain in that direction can wrap around the sprocket, jamming themselves between the bar cheeks and sprocket bearing.
If it's a greasable tip, you can probably pump enough grease through it to eject whatever debris is causing the binding. But if it's a Still Rollomatic bar, just toss it, they're not greasable.
... and now you know why I rarely buy Stihl bars, anymore. :D
   / Frozen Sprocket #3
Just in comment
I bought a Husky 550xp this morning, roller tip, but no grease port.
I guess that's why the "tool kit" didn't come with a grease gun. Now I wonder about the clutch bearing......
   / Frozen Sprocket #4
If you are cutting real sappy pines the bar and chain will be hot and sap sticks to it. When the saw sits, the gooey sap turns hard and will freeze stuff up. Free it up and lube it, you'll be fine. Turn up your oiler a bit and lube before storing the saw.
   / Frozen Sprocket #5
Yeah, I’ve run into that a couple times, usually after working with dry or dusty wood like old dead pines. The fine debris can mix with bar oil and harden around the sprocket, especially if it sits for a few days without cleaning. If the sprocket was hot and cooling down, it can also kind of “set” things in place.
   / Frozen Sprocket #6
Being from the northeast, I sometimes forget that people in some parts of this country actually cut and burn pine. :p
My stoves traditionally eat only oak and hickory, although they've been seeing an awful lot of ash since the Emerald Ash Borer made it out here the last several years.
Pine and all other connifers get left to rot where it falls, or pushed into the burn pit. If I lived in a place where oak, hickory, and ash weren't plentiful, then I'm sure I'd burn it. But around here we always have enough hardwoods dying or on the ground, that it's just not worth wasting wood shed space on connifers.
   / Frozen Sprocket #7
per ton, there is more heat in the conifers. But that ton IS a LOT of volume. ;-)
I do burn a lot of hemlock. In fact, that's what is in the stove just now.
Along with a couple sticks of birch to keep the fire going. ;-)
   / Frozen Sprocket #8
lol... yeah, that's true! But my stove's firebox is limited by volume, not so much by weight.
Just loaded two of our stoves for the night. Mostly oak, with a few pieces of ash, but somehow one split of red cedar ended up in the mix. I usually save the cedars to use as sleepers, to place on the ground under my piles of logs waiting to be split.
   / Frozen Sprocket #9
Tip did that on one other day. Prob just compacted chips fines tight in around tip inside. On my own saw cutting maples.
Actually see it here from time to time on saws that come in. a 24" was real bad on a 660. Ended up free it. It even took a soaking.
Put bar in vise. Get you a flat blade screwdriver put on one V and start hitting them to turn it over. Also using lubricate to spray to help with remove.
Keep doing to free completely again.
2018 KENWORTH T680 (A45046)
2018 KENWORTH T680...
PENDING SELLER CONFIRMATIONS ON SOME LOT #'S (A43004)
PENDING SELLER...
2016 GMC 2500 HD Z71 (A44501)
2016 GMC 2500 HD...
Wacker 8500 (A42021)
2020 Chevrolet Equinox LS SUV (A42744)
2020 Chevrolet...
2005 BLUE BIRD SCHOOLBUS (A42021)
2005 BLUE BIRD...
