19th_VA
I was using my 5' medium duty rotary cutter with a slip clutch the other day (80 hp gearbox) when I hit a stump and whack, the engine immediately died (unusual because it usually chokes and then is fine if I quickly raise the cutter above the obstruction). I had been using it for several hours before this happened, seemingly without problems.
Now when I try to engage the pto with the cutter, it dies immediately (and I mean quick) /forums/images/graemlins/confused.gif. Perhaps I erred in using the cutter without first slipping the clutch, as it had been 10 weeks since it's last use. Any help us much appreciated.
