Frozen pipes = new kitchen ceiling.
   / Frozen pipes = new kitchen ceiling. #1
zing
Platinum Member
Nova Scotia, Canada
Case IH 1390
There are no tractors involved in this thread, so I will not be offended if you choose to leave right away... I totally understand. :)
Still here? Ok, well our farm property is not our full time home yet, that is a retirement dream. For now it is our weekend retreat for horse riding in the summer and skiing at the local hill in the winter. For that reason in the winter it is not occupied during the week. I leave the thermostat set to 10-12 degrees and I turn the water off and open the taps so the pipes will drain before I leave on Sunday. I have never had a frozen pipe in the 9 years I have been doing this, but as luck (or stupidity) would have it I neglected to open the taps one Sunday last winter and that week we had a few days straight of -20 to -25 degrees coupled with high winds. The wind was bad enough that the cold penetrated the soffit under the second floor dormer and froze the pipes behind the tub for the second floor bathroom, even thought the rest of the house was 10 degrees. By the time we pulled in on Friday night it had warmed up enough that the pipes had thawed and cleared, but there was no clearing the split elbow. Having the water off meant that the water wasn't running for days, so damage was minimal. Nevertheless, by the time I turned on the pump in the basement, walked upstairs to my wife yelling "I hear water in the walls!" and then my daughter commenting that there was water running through the kitchen light fixture, and then ran back downstairs to shut it off, the damage was done to the kitchen ceiling right below that second floor bathroom. The only visible damage was some saggy drywall seams and wrinkled paint, but in order to locate the leak the plumber and I had to tear a good piece out and follow the pipes to the elbow that was split.
My insurance guy just wanted to put in some patches and redo the saggy drywall seams but I insisted that I wanted that whole ceiling to come down due to mold issues, so we settled for this. He got a couple of quotes to replace the drywall on the half the ceiling directly under the pipes and repaint, the lowest one came to $2150. My deductible was $1000, so he wrote me a cheque for $1150 and told me to go have fun. That set the budget for my repairs. :)
The plumber fixed the leaky pipe and I pulled down the wet drywall but the actual repairs had to wait until spring when ski season was over. Can't miss time on the hill! This place is a 180 year old farm house that has been added onto by any number of previous residents and at one point after WWII was abandoned long enough to allow a family of porcupines to walk through a hole in the wall and set up residence in the living room. For that reason you never know what you are going to find when you look behind the walls, except for mouse droppings. You are guaranteed to find those.
I took down the rest of the old drywall and replaced the single light fixture with 6 potlights. I am using CFL bulbs so the amperage draw is actually less than the 100 watt bulb that was in there before, so I didn't change the fuse or the wiring to supply it from the panel. I also know that there is nothing else on that wire other than the outlet that the microwave is plugged into because I traced that wire last year while I was running wire from the panel for a new dishwasher that I installed. I didn't do anything fancy, just arranged them in two rows of three, but I did make sure one of the corner lights was over the stove and I offset one of the middle ones so it was over the sink, to make those two workspaces a bit brighter. I also did some fixup of the drywall at the top of the walls where it was damaged by the ceiling demo.
That ended up taking the whole first weekend, because I started by tarping and taping all of the cupboards and doors and putting a box fan in a window to try and suck the dust outside and minimize the cleanup I would have to do afterward. Prep work and cleanup can take longer thatn the actual job!
   / Frozen pipes = new kitchen ceiling. #2
I suspect that given it looks like you are doing the work yourself that materials for this job should still run under the $1000 cheque you got from insurance. But if you need to sub out some of the work then this will hit the pocket book further.
I do suggest that if you have the cash....... to add sound insulation between your kitchen and upstairs.....it is one of those things you can only do now. And the $150 extra dollars will be well worth it if you don't need to hear your toilet sounds (and groans) from upstairs........... :)
Old farm houses around here used to be built with wide plank softwood floors, but when we bought this place this is what they looked like. Under the carpet was plywood nailed to the softwood so there was no way to pull it up without splitting the whole thing to pieces.
Instead I decided to redo them. All of the carpet came up and I put a layer wideplank softwood right over top (with some craftpaper in between to prevent squeaks) for the whole house except for the kitchen and bathroom. It brought back the character of the old farm house and after 9 years they are still holding up well except for some scuffing of the finish. Kids and dogs will do that...
I wanted to keep that feel with the kitchen, so I decided to do a wideplank softwoo ceiling. Started off with this from my local lumber yard.
All I did was staple at the tongue into the existing strapping that had been there for the drywall, so there wasn't really anything to do other than put it up there, and progress was pretty quick. Had most of it up by the end of the second weekend.
The third weekend was spent finishing the last couple of planks, repainting the walls (I patched some other wall damage while I was repairing the tops so they all needded to be painted), running quarter round around the edges, oiling it, and then cleanup. The medium stain I used on the floors would have made the kitchen too dark if I used if for the ceiling, so I just used a couple of coats of tongue oil. Pretty pleased with the results though.
Now one of me future jobs foir the next year or two is replacing those old plywood cupboards with something a bit nicer. :)
   / Frozen pipes = new kitchen ceiling. #5
Looks great...........ignore my post you are obviously past that stage and went with a much nicer looking ceiling than using drywall that I assumed you were going with.
I wish my hardware store had that wide pine T+G , and at that price........we don't see that product.....good choice !
   / Frozen pipes = new kitchen ceiling. #6
Nice! You've been busy.
   / Frozen pipes = new kitchen ceiling. #7
Looks great zing! What was the name of that song by Lionel Richie lol.
Sorry, I guess I didn't clarify, I did this job in the spring of this year.
Oh yeah, well under. The wood was under $400, and the lighting about 150 if I remember correctly. A gallon of paint for the walls, some staples, tongue oil, quarter round, etc another hundred. Even my gas for three trips to the farm was covered at $75 each trip. I definitely came in under budget.
You make a good point about noise, but insulating between the floors was not an option. As a matter of fact it is the opposite of what I needed. The pipes that froze had been fully wrapped with fiberglass insulation by some previous owner, probably during a bathroom upgrade. Over the years that insulation had soaked up a lot of water due to condensation off of the pipes. When that freezing wind came whipping in through the cracks, it managed to freeze the pipes inside the walls even though they were not on an exterior wall and even though the rest of the house was at 10 degrees. The pipe insulation managed to let the cold in but there was not enough air circulation to overcome the impact of that strong freezing wind through any tiny wall crack that existed in the exterior walls and insulation. As well, I think if the exterior wall had been a normal wall it would not have happened, but since it is a dormer with a soffit between the first and second floow, it gave more places for cold wind to get through.
One of the things that I had to promise my insurance guy was that I would improve the circulation of warm air into the walls below the bathroom to ensure that the warm air from the house gets to the pipes so it wouldn't happen again. You have to remember, this house is unoccupied a lot of the time during the winter, so compromises have to be made between sound insulation and air flow. I accomplished that with a vent in the ceiling in the corner closest to the pipes, and another vent in the stairwell that the shower pipes back onto. This allows warm air to flow up from the kitchen, past the bathroom pipes, and out into the stairwell to the second floor. You can see the ceiling vent in one of the pics above (next to the cheerios), and here is the stairwell vent. It is actually bigger than I needed, but since I had already cut the hole to get at the pipes to fix the leak, I just decided to get one big enough to cover the existing hole and minimize my repair time. :)
ClubCar Electric Golf Cart (A42744)
ClubCar Electric...
New/Unused 10ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 10ft x...
2016 Nissan Sentra Sedan (A42744)
2016 Nissan Sentra...
Bush Hog Triple Deck Pull-Behind Bat Wing Mower (A44571)
Bush Hog Triple...
2008 Sterling Bullet 4x4 HT40KX Crane Service Truck (A42742)
2008 Sterling...
2011 Nissan Pathfinder AWD SUV (A44572)
2011 Nissan...
