Madman_Mark
- Joined
- Nov 19, 2003
- Messages
- 49
When the teperature goes down well below freezing the joystick that controls the FEL on my tractor freezes up. It's a 4WD Fiat 55 HP.
Sometimes it slowly raises but won't curl (or sometimes the other way around).
I usually have to put the hair dryer to it for 5 or 10 minutes to get it working.
I'm changing the hydraulic/transmission fluid in it this week, will this end my problem (the fluid in it now has a little moisture in it) ?
I leave the loader raised at night so it doesn't freeze while it's on the ground.
I was told I should always leave it raised overnight during freezing weather, is this true ?
It also slowly lowers on it's own during long periods of time, is that normal (I suspect it is) ?
