Frontier AV20 Root Grapple-Need info
   / Frontier AV20 Root Grapple-Need info #1
Bliz
NH-9 Miles from Quebec
I am purchasing a new JD 6115 tractor to be used primarily for tractor logging in the winter and am trying to decide on a root grapple. Ideally, I want to stick with the Frontier AV20 grapple because I can finance it at the same time I do the tractor at a good rate. My questions are, does anyone have this rake now and do you think it is rugged enough to use for moving logs and brush on a regular basis? The price ($4,600.00) is not really an issue because it is within dollars of a custom built Addington rake I was considering. Thanks for any help. Bliz
   / Frontier AV20 Root Grapple-Need info #2
I guess it must be gold underneath the green paint. It doen't look like anything special. How about markham or WR Long grapples? I know Markham starts under 1000 for a light duty grapple. Alot of people sell their grapples on Ebay.
   / Frontier AV20 Root Grapple-Need info #3
I've not seen the specs/weight on the AV20 but from the photo in the JD catalog I'm surprised that they are charging $4600 (even if those are Loonies). It doesn't look any heavier than a standard duty Markham or WRLong. The Markham can be had for about a third the price and the WRLong for about half. The Frontier price even tops some of the high strength steel grapples like ANBO. That green paint sure is expensive.
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
