Front wheel width adjustment on 4WD (TL2800F)
   / Front wheel width adjustment on 4WD (TL2800F) #1
HurdleMills
Central NC
Iseki TL2800F and JD 1020 (and the JD pedal tractor grampa gave me in '57)
For stability, I'm in the process of widening the wheel base of my TL2800F with factory FEL. Rear wheels were at 'full in' width of 44.9" and I'm moving them to 'full out' width of 59.1". I'd like to widen the front wheel base too, but the manual (White 2-32, which for all I can tell is the same tractor) says that for the 4WD, "Front wheel tread is permanently established at 47.6 inches (1210 mm)." For the 2WD model it says the wheel base can be widened out to a max of 61".
Questions: Can I safely move the front wheels out on the 4WD? Note that, because the the 4WD wheels are "1-piece wheels", it's all or nothing. I'd be just be able by swapping sides with them (left to right and vice-versa) to increase the front wheel base from 47.6" to approximately 61" (if my measurements are right), but won't be able to go anywhere in between. I expect that this would add stress to both the wheels and to the hubs...how hazardous or potentially damaging would this be?
Thanks,
Steve
   / Front wheel width adjustment on 4WD (TL2800F) #2
Steve,
It will put extreme pressure on your bearings. That is why the manual said they were permanent. Moving the front wheels out would help very little if any for additional stability, because the front-end pivots side to side. The only time that the extra width might help on the front-end would be if the axle is setting on the locks.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
