Front wheel spacers?
   / Front wheel spacers? #1
troverman
NH
Kubota MX6000 Cab
I have purchased aluminum wheel spacers from Bro-Tek on several tractors in the past, on the rear wheels, to widen the stance.
I noticed they also have front wheel spacers. Would adding front spacers help reduce rollover risk on side slopes, given that the front axle is on a pivot? Would it cause undue stress on the front drivetrain, such as when using a loader, when operating 4x4, or just turning?
I would be considering 2" spacers on the rear, and also possibly on the front.
   / Front wheel spacers? #3
Gonna probably depend on size of the tractor. I have the 2in BroTek on the back and the 1.25in on the front of my BX. Yes, the spacers on the front make a difference especially turning on a side slope. I went with 1.25in on the fronts for two reasons. First I was a bit concerned about the stress on the axle as I had a bunch of loader work in front of me, second, they wouldn't interfere with a belly mower as a 2in spacer would. Ended up not getting a MMM and got a Z turn because of losing the ground clearance and no quick way to remove the MMM.
   / Front wheel spacers? #4
In a static situation, technically the answer is yes. At that last little fraction of a degree of rolling over it will help prevent it. However in a dynamic situation (you are driving it, right?) the answer is almost assuredly no. If you have lost it that badly, the momentum you have to roll probably will not be affected by that last little blockage. I mean, the front axle alone would offer you a 1% (?) chance of helping, but that extra inch wider might get you to 1.00001%. Not worth it if you ask me, but oh yeah, you did! :D The amount of safety margin this adds is not zero, but it's close.
All of the above. You have added leverage in every direction possible and if you're thinking of it for loader work, just that much worse. I wouldn't do it.
   / Front wheel spacers? #5
I understand where you are coming from static vs. dynamic loading but keeping with the go low and slow mantra I believe they are worth it to me. Not as effective as spacers on the rear but but if I was a betting man I would say you get more stability than the nearly zero that you are estimating.
   / Front wheel spacers? #6
Hey Dragon,
I know you've done a ton of landscaping on your property on the mountain. I remember reading your thread while you were building your retaining wall. I totally respect your opinion and skills. But I gotta ask, is this a feel-good thing? I mean, they haven't actually helped you unless you had at least one rear wheel off the ground and ready to go greasy side up. And at that moment, would you be able to tell that it was the spacer that saved your paint job? I can't help but be skeptical.
   / Front wheel spacers? #7
Hey Dragon,
Okay call it a feel good thing... I can accept that.
Yeah I have had one wheel off the ground multiple times unfortunately because I 'push' it. :eek: Again, strongly emphasizing low and slow and being very deliberate. I've had both rear wheels off the ground although that was simply trying to lift too much with my FEL facing straight downhill. Having two wheels on the same side off the ground has been one of the worst feelings I can remember. Dropping the bucket and leaning uphill FAST like I'm a Grand Prix motorcyclist, except they are having fun. Then taking a deep breath and then figuring how I am going to get this thing righted.
You are right though... no way to measure the effect of wider spacing but I see it as worthwhile insurance. Plus it makes your tractor stance badder! :cool: Kidding (sort of).
We won't settle this but but I'm glad I have the spacers on my tractor and who knows, maybe I would have already gone t!ts up without them. :confused3:
I can only speak for SCUTs but I will always recommend wheel spacers for anyone operating on a hill with any significant slope.
   / Front wheel spacers? #8
All the bump-steer I was getting was not worth it for me, so I changed it back to the way my tractor was.
   / Front wheel spacers? #9
Hey Dragon,
The only time a front spacer wpould "work" would be when you lifted a rear tire so high into the air that you found the mechanical end of the front axles pivot, when you hard stop the front axle pivot..... should your tractor now stop rotating over.... you can now say that adding the front spacers may have helped. The truth is that once you are on a ground slope that gets your rear rotating sideways and then you add the freedom of motion built into that front pivot, the frame/engine/rear axle will now have pivoted so far that you are not stopping the roll over.
The only reason a front spacer can be useful would be to spread tire width out to negotiate crop rows or ruts. As for roll over prevention, you would need 5 foot long spacers to make them at all useful! They are an utter waste of money sold to people who are not knowledgeable in basic engineering/physics principals. And that would be about 75% of the population.
I'm sure that those that buy them feel better for it, and like most... will defend it t the grave.
Thanks for the replies. My only question regarding front spacers is the following:
What is more stable...a tricycle tractor or a conventional front end tractor, both with identical rear tires and track widths, on the same side slope?
It seems to me there has to be some point where more front track width, even on a pivot, is worth something.
I flail mow on quite steep side slopes; have done it for years now on the same slopes without a rollover. I am definitely operating under the slow, deliberate, and low mentality.
Thoughts?
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
