Front Wheel Hubs
   / Front Wheel Hubs #1
kn6md
Yerington, NV
YM1601D
I have a YM1601D and the YM226D manual I am reading says that at 600 hr intervals I should "Renew front wheel hub grease".
Does anyone know what this entails?
Thanks,
Bill Vorhies
   / Front Wheel Hubs #2
Probably wants you to repack the front wheel bearings ( in grease ).
Ive seen people pack them by hand, or they sell a little plastic job that you put around the bearing and squeeze grease into it.
The real experts will also probably answer, but I think I am on the right track.
Chris
   / Front Wheel Hubs #3
Oh yeah.. forgot to ask, is "Kn6md" an amature radio callsign?
If so,
de Ke4rrd
73's
   / Front Wheel Hubs #4
I think that is refering to the 2WD model. I think on the 4WD axle the bearings are immersed in 90 weight oil. The manual calls for changing the front axle gear oil every 300 hours.
Chris
   / Front Wheel Hubs #5
For some reason I wasn't seeing the "D" and had assumed he had a 2wd model.... I think I need more coffee..
Chris
   / Front Wheel Hubs
Many thanks, folks. It is a 4WD, so I will just change the 90 wt oil at the appropriate interval. I checked it and it is clean.
kn6md is my call sign, but I use it so infrequently I made it the username in my e-mail address so I won't forget it.
Thanks again for your replies-
   / Front Wheel Hubs #7
de w8dvm
Sounds like there may be a few radio amateur/Yanmar enthusiasts.
   / Front Wheel Hubs #8
If you think about it it makes sense. Yanmar owners usually need to be a bit 'handy', and amature radio op's are generally the same way... we make our own arials, etc...
73's
de ke4rrd
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
