Front Wheel Assist
   / Front Wheel Assist #1
Task
What is the proper way to use FWA, and is it hard on FWA when turning?
   / Front Wheel Assist #2
Some people only use it when their stuck or when they feel that they need the extra traction. Others including me never take it out of 4x4 mode. Remember that when the tractor is in 4x4 mode, you then have all four wheels for braking, but in 4x2 mode, only the rears brake. About the only time that turning in 4x4 mode is really hard on the drive train is when all the tires are on a hard surface, such as asphalt.
   / Front Wheel Assist #3
I engage it when it is needed, which is most of the time that I am working the tractor and not just cruising from place to place.
   / Front Wheel Assist #4
My tractor automatically engages FWA. I have found that when I am maneuvering in a tight spot it sometimes has a hard time figuring out when it is needed (the sensing is some kind of torque sensitive device, likely a torsion bar) and it can be out foxed. In those situations it can be hard to turn and really digs the ground up more, but that is rare, and I am learning when that occurs and shut it of, or accelerate after I have turned. If you have ever driven a conventional 4wd truck and tried to turn and accelerate you will know what I mean. And yes, it is harder to turn (more than a little bit) with it engaged. Especially with higher traction tires (like R1's).
With the auto engage, I think it is working as it should in a turn -- it senses a differential pressure between front and rear wheels and applies power to the front axle, which may not always be better.
Like most things, if you wind up the engine and drop the clutch, you will eventually break something.
   / Front Wheel Assist #5
mojoinco
Which tractor do you have that has auto engage?
   / Front Wheel Assist #7
When mowing a pasture 2-wheel is enough and doesn't tear up the grass maneuvering around the sprinkler heads. When turning the compost pile with the front end loader I'd want all four wheel pushing.
Wm
   / Front Wheel Assist #8
With FWA the front drive is slightly positive vs the rear. That means that the front tires are trying to cover the ground a little faster than the rear, that is how they assist. The evidence is that, in softer soil, the fronts will exhibit a tendancy to move the soil a bit as compared to the rears. As noted above, try not to use FWA on hard surfaces as the driveline will "wind up" and will be evidenced by difficulty is disengaging the FWA without backing up a little. Otherwise, use it according to your sense of need, it won't hurt anything other than scuffing the turf in turns.
   / Front Wheel Assist #9
Mostly a matter of common sense...
I use FWA whenever I'm using the loader and plowing snow. I rarely use it when I'm mowing except in one area too steep to mow across (small area, but sloped to 35° to 40°) when I'm backing up and down. Brushcutting is when I need it (not too often).
BTW, if you're using the loader, up the inflation pressure in those front tires. I take mine to the maximum pressure called out on the sidewall.
   / Front Wheel Assist #10
I only use 4WD doing loader work. You don't want to leave it engaged on hard pavement or running down the road. That's hard on them.
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2012 FRAC TANK (A53843)
2012 FRAC TANK...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2011John Deere 244J (A47477)
2011John Deere...
