Ballast Front weights
   / Front weights #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader and Kubota B2910 w/ loader.
Will the suitcase weights for a newer NH compact fit the bracket on a 1910?
I'm putting a 6ft 3pt King Kutter bush hog on it and may need the some added weight.
   / Front weights #2
If not.. fab a bracket that will.. and then bolt it to the factory one.
I know the 50# fat suitcase weights that CNH sells fit my Nh 1920 front bracket.
A bracket doesn't have to be muchmor ethan a flat for them to hang on.. then a locking bolt.. etc.. make sure that bracket then bolts to the oem one.. etc.
Soundguy
   / Front weights
I was at my NH dealer yestreday picking up my new clutch and few other parts, so I asked about weights and the ones for the newer Boomers will fit. I measured the weight bracket on a TC30 and they are close enough to the same that they will work.
They sent an extra drive clutch plate with the clutch pack, so when I return it I will be picking up 3 weights.
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2019 FREIGHTLINER CASCADIA T/A DAYCAB ROAD TRACTOR (A51243)
2019 FREIGHTLINER...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
TRAILER AXLE (A51244)
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
