Front weights for snowplowing
   / Front weights for snowplowing #1
390GT
S.E. Michigan
New Holland TC33DA
When using my front blade for pushing snow to the side, tractor front will sometimes be pushed in the opposite direction. Meaning I am not moving the snow or a least not moving it as much. I thought adding front weight would at least reduce this unwanted movement. Dealer said he would be happy to sell me the weights (100 lbs.for each wheel) but they WOULD NOT help with this issue. I thought they would? Comments Please. Thanks Greg P.S. I have turf tires.
   / Front weights for snowplowing #2
How much do the weights cost? I just paid $230 for (2) 60# suitcase weights:eek: I paid $400 for a used 3pt blower. See where I'm going...
Snow is heavier than you might think - I have my rear Industrial tires loaded on my TC18 - adds 400# to a 1,600# tractor. My 5' rear blade would push the rear of the tractor off course in anything but the fluffiest of powder snow. when plowing I have to plan my course & pretty much push straight (angled slightly to keep the previous lane clear).
I have had much better results with the blower.
Here are some action shots blizzard of 2005
   / Front weights for snowplowing #3
I raise the blade off the ground about 1" to 2" for the first pass when plowing heavy snow. You will need weight on the front wheels to make the steer. Adding weight may help but I believe you will need more than the 200 lbs the weights will add.
Hazmat, I did not ask the price. I had no idea weights were that expensive.
ronjhall, Steering is the real point. When tractor moves in the opposite (unwanted) direction I try to steer it back on course. Do you think 200lbs. is not enough to get the traction needed to steer? Thanks to both of you for your responses. Greg
   / Front weights for snowplowing #5
Greg, front weight will help significantly. I think I might start with loading the front tires with RimGuard and see if that helps. I'm very surprised that with the weight of the FEL frame you are having such difficulty.
djradz, When pushing snow I don't have FEL on tractor, just it's mounts. Front blade mounts to subframe under tractor. I put loader/FB joystick in float mode so I don't even get the weight of the blade itself helping with the traction. Raising blade alittle would put more weight on front tires but means going over area twice to clean snow. Thank you for your input. Greg
   / Front weights for snowplowing #7
The main problem you are experiencing is that the sideways force from the angled blade is acting to push the tractor sideways, overcoming the straight forward push from the wheels. Have you tried a different approach angle? If the blade is set at more of an angle, the division between forward and sideways thrust will be different and you might find it will work just fine. You could also just leave the blade square for the first pass, then make a second and third pass to push things to the side after you can get more traction in the middle of the drive. It all depends on the snow you're pushing.
Snow is funny stuff to move around. Sometimes it's light and fluffy and moves easily, sometimes it's like thick mud. The traction you can get while plowing varies a lot.
I think if I was you I would look at chains on the tires before weights. Granted, you may need to be careful when turning, but you'll get more traction from chains than from more weight on hard pack or ice. I think chains for the front may be cheaper than weights, too.
Another option is to spend less money and get a back blade (or use one you may already have) for the first pass and the front blade for the more delicate precision parts of the job. I lived over by Muskegon in serious snow country for several years. I had flat ground and plowed my snow with a rear blade on an 8N with unloaded Ag tires and no chains. I had no problems moving considerable amounts of the stuff. Again, the ground was flat, I had lots of room to work in, and didn't worry about the lawn and such. To put it in perspective, a lot of people over there plowed out their whole yard at the start of winter. I asked why, and they said it was so in case of a "good ole Michigan winter" they would have enough room to pile all the snow as the winter progressed.
   / Front weights for snowplowing #8
Is you front blade mounted to tractor or FEL. Mine is mounted to the FEL. If yours is mounted to the tractor you will not have the weight that I have. My tractor has Turfs also. Here is link to a photo. http://www.tractorbynet.com/photos/showphoto.php/photo/1003/sort/1/cat/500/page/1
ronjhall, My front blade mounts to a subframe under tractor not to loader arms.
dateacha, Chains for front might just be the answer. Using rear blade more at first in heavy snow is also a good idea.
Thanks to both of you for your thoughts. Greg
   / Front weights for snowplowing #10
I'm working up a little project which will allow me to use my rear blade on the back or to attach just the blade part to my FEL. I have a thread in the projects forum, but am waiting on a part to finish the job and post more pics. Experience with my Cadet has taught me that a front blade is usually best for snow, so consider setting the thing at a really steep angle before you do anything else. Unless of course you just like to be prepared for the worst before it happens. Then do everything you read about here! :)
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
New/Unused Forklift Jib (A51573)
New/Unused...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
