Front weights for a MF1010
   / Front weights for a MF1010 #1
kaferhaus
Bronze Member
Mobile, Alabama
Kubota BX24
I'm in serious need of adding weight to the front of my SCUT 1010. The manual says you can add up to 150lbs of weight to the front. The factory weights are no longer available.
Anyone know what other brand weights would work or better yet how I can fabricate some or adapt some other material to use as weights?
Not looking for wheel weights if I can help it but that may be an option if anyone has any ideas on those.
   / Front weights for a MF1010 #2
I went out and bought current issue MF suitcase weights for mine, and had a tray made for them that bolts onto the front of the tractor frame. You just need to get the back side to match the frame and make the front end the right height to hang the weights on. By the way, mine is wide enough to handle 6 weights, which is around 275 lbs. I had them weld a "floor" in the bottom of the weight tray so I could toss in a chain or two, and I made sure to leave a gap at the bottom of the tray to drain water.
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
3in Poly Pipe (A49461)
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
