Tires Front tires...wider option?
   / Front tires...wider option? #1
couchsachraga
Adirondacks, NY, USA
John Deere 4520 cab... formerly Yanmar 336D
Just curious...has anyone ever put wider front tires on (is it even possible?) I seem to have plenty of clearance on my YM336D, and will be working with a loader or grapple on some soft ground this spring / summer (I did last fall too....the only time I've EVER gotten seriously stuck. It took me abotu 2 hours to get out...would have been easier if the rear end wasn't sitting on an old stump buried in the soft muck I sunk into (under a nice tall, grassy field I was attempting to mow).
I know I don't want to go bigger, as it will throw off my axle ratio, so I was wondering if it was possible to go wider on the same rim, or what other tricks others may have used in the past.
Thank you in advance for your time,
Couchsachraga
   / Front tires...wider option? #2
I had Hey Wheel make rims for wider tires. I put industrial tires on front and rear. The industrials let you go wider without changing your ratios.
   / Front tires...wider option? #3
Every time I go to Hey Wheel's web site, it doesn't load properly. How much does making new rims cost on average?
Do they already know lug nut patterns for the Yanmars or do you have to send them a rim or measurements?
   / Front tires...wider option? #5
At this point, I'm just curious about how much and how to get them made. It's not a high priority right now for me.
However, If they are cheap enough I might bump them up on my list /forums/images/graemlins/ooo.gif
Jerry
YM2000BD
   / Front tires...wider option? #6
They have some patterns in memory, but it is easy to measure for them. 785-594-3441 ask for Bob. Tell them about the web page. It won't load on my computer.
I can't find my invoice for the front wheels or I would tell you what they cost.
2020 KUBOTA RTV...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
