Front tires on YM 2210
   / Front tires on YM 2210 #1
broncobisley1
I need to replace the front tires on my 2210 (2wd).
What is the correct size of tire and tube and where can I get the tires and tubes. I did a very quick search and couldn't find my answer. (My tractor is over an hour away at the moment).
My 2210 is fairly new (to me), purchased from Spalding Tractor, who gets his from Fredericks. The original rear tires are holding up fine, but the Chinese replacement front tires are falling apart after less than 50 hours. I already have had one flat and have patched several holes, but the rubber seems to come apart easily. I'm looking for a quality tire.
I've enjoyed the heck out of this little tractor, very pleased with it so far.
Any input would be appreciated.
Thanks,
Thanks,
I found a couple of different brands searching for that size, Firestone, Carlisle, Harvest King, ect...
I found one place about 45 minutes away that can get the Firestone ones for around $65 each and Harvest Kings for around $50 each and has tubes, or I'll just order the Carlisles for $46 each online. Will have to find someone to pick them up for me if I go with the local store since they are closed on Sat.
Can't wait to get the little tractor going again.
Just wanted to say thank-you. I ended up getting the Firestone tires, and some spare tubes from a tire place in Gainseville.
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2014 FORD F-350 (A53843)
2014 FORD F-350...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
