front tires leaning out
   / front tires leaning out #1
Ginormous
Dayton, Ohio
Yanmar YM2210
I just purchased a YM1700. I've been doing little things to make sure it's running well -- like flushing the radiator. I noticed that the tops of the front tires lean out a few degrees (didn't get around to measuring it yet) compared to the rear tires. Is that normal?
   / front tires leaning out #2
I wish I had a definitive answer for you, but I am interested in any answers because my new Kubota L3400 is the same way. I have asked some folks around here and they don't know either.
   / front tires leaning out #4
Normal. Its called camber or "toe in" I haven't seen a 4wd tractor where the front tires didn't toe in. My L4400 is VERY noticeable.
Awesome, thanks for the info guys! :thumbsup:
   / front tires leaning out #8
i was told that it has to do with what happens when the loader is full....the weight will push the tires out to more of a vertical position. The camber helps compensate for this when it happens. not sure how true that is....but its what i was told. My tractor has it also.
   / front tires leaning out #9
Now, for the obvious followup question; Why?
The manual says it is to make steering easier. I can't explain the physics of how that works though.
   / front tires leaning out #10
i thought it had something to do with making them run true, or that it helps return the wheel to center after a turn is made. At least i know thats why alignment on a automobile is important.
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2022 Isuzu NPR 20FT Box Truck (A51692)
2022 Isuzu NPR...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
