Front tire size for 1020 Deere
   / Front tire size for 1020 Deere #1
Blueflint
Winchester, Ohio
Deere 1020
I have a 1973 1020 Deere and it is time to replace the front tires. The original Firestones are 16-6.00 two rib. Can I use 16-6.50? What about the width difference? There is 1" or so clearance between my tire and the steering/chassis (knuckle area). Or...stick with the 16-6.00?
   / Front tire size for 1020 Deere #2
You should be fine to go bigger. Usually the rims are reversible. It puts the valve stem on the inside, but gets you further away from the axle. What width are the rims? If they are 6" you could even go up to a 7.50-16 if you wanted.
   / Front tire size for 1020 Deere #3
Mine has 6.50-16s and no problem. 7.50s will fit width wise, but are quite a bit taller, so lowers the drawbar too much for me.
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
NISSAN 80 PROPANE FORK LIFT (A53426)
NISSAN 80 PROPANE...
