Front tire lug bolt loose
   / Front tire lug bolt loose #1
meexiles
So a lug bolt on the front tire of my 354 has become loose. I have replaced the lug bolts on one of the the rear tractor tires. Are the front ones fastened similarly to how the lug bolts in the rear affixed? It seems like it may be a different fastening mechanism, though, since the loose lug bolt on the front can move depth wise, which makes me think it is not pressed in like the rear ones are.
Thanks for your help!
   / Front tire lug bolt loose #2
If it keeps working loose, the threads have stretched. Take it off and order a replacement. But it's an indicator that they might all be stretching. If it was my tractor, I'd replace them all at the same time. Kinda the same thing as a gasoline engine; you don't replace just one spark plug, you replace the whole set.
//greg//
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
