Chains Front tire chains
   / Front tire chains #1
bstrom
Platinum Member
Maine
kubota b2620
Wondering what the consensus is on using front tire chains. I've got chains on the rear but notice the front wheels spinning sometimes especially when pushing a lot of snow backwards with my rear blade. (We get a lot of ice and wet snow here). Wondering if it could cause any damage using front chains with rear chains. Kind of like how you are not supposed to run 4 wheel drive on dry pavement, you want a bit of slippage. Don't know if it's the same principle.
It seems like if I had front chains I would never lose traction when pushing or pulling big snow piles.
   / Front tire chains #2
I know a lot of manufacturers frown on it. personally I'd rather have some slipping then a torn up front end. Seems like this topic comes up about once a week on here?
   / Front tire chains #3
Nah - not that often, hardly came up at all last summer. Besides, maybe the search function froze upi.
   / Front tire chains #4
I have chains on all four and so far haven't had any problems. (2 link, v-bar) The front chains do improve both traction and steering. I only engage fwd when needed and run in 2wd most of the time. I would be more concerned with bending your 3pt hitch arms by pushing snow back and hitting something. The 3pt hitch is designed for pulling, not pushing.
   / Front tire chains
Thanks for the sarcasm guys, gee, just asking. Next time I will search longer I guess. Maybe you should have skipped the post?
As far as pushing with the three point hitch, I only push backwards when the snow gets to deep to pull. Trying to drive through 12 inches of snow plus pull it behind does not work to good, you lose traction. Pushing snow is not that hard on the arms and I know where all the things to hit are in my driveway. I go slow.
   / Front tire chains #6
I have had the same question regarding front chains. I have a front blade and a front snowblower and many times I will find that the blade or blower will steer the tractor rather than the wheels. I was wondering if front chains might improve this somewhat by giving me some extra front traction.
   / Front tire chains #7
I was not trying to be sarcastic, just saying this has been discussed a bit :)
I wouldn't worry about pushing snow, doubt highly it would bent the arms. Folks around here have been pushing snow for YEARS without any troubles. You are correct once the snow gets high it is darn near impossible to pull through it, pushing works fine.
You never said the make of your tractor? Maybe you could call a dealer and see what they have to say? IMO my machine will never see front chains, to much stress. The ice and snow would not be the problem it is what lies underneath that would snag/catch that would cause the breakage. The way I figure if I couldn't move the snow, then maybe I need a more capable machine. I have a drive over 1000' long with a few very wide parking spots. I plow with a 25hp 4x4 compact with rear chains, never had a problem.
   / Front tire chains #9
I've had chains on all 4's year around for over 10 years with the dealers blessing...we do a lot of excavation and logging. Makes a huge difference in performance. We don't go on a hardball road.
   / Front tire chains #10
I added front tire chains and felt they helped a lot getting through deep snow.
I removed the rear chains and left the front ones on for a while. Sure did help get traction, but felt the front wheel assist was being over-taxed when the rears could/should be doing most of the heavy work.
So I removed the front chains, and will only use them when needing to go into the woods (like last week to retrieve a bow-shot deer) and when the rear chains are also mounted.
Just have to go with your gut feeling if running front chains.
Deere engineers told me that their front wheel assist is designed to be on all the time and to not fear running on dry or hard roads. Said they are built for that too.
But I don't like the extra whine I get when on hard pack and in 4wd. So I kick it into 2wd when/until needed.
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
