Snowblower Front snowblowers and Kioti
   / Front snowblowers and Kioti #1
JCA
Maine
Kubota B7510
Just had a long chat with a Kioti dealer. He said I'd need to use a rear snowblower; said the ones that go in front were too expensive, and...well, he didn't seem too sure what else.
Kubota sells a front snowblower for around $2800 (that's the one for the B series), and I know Woods makes one, though I don't know for what tractors, or how much they cost.
What's the real story? Is there any reason why I couldn't put a front 'blower on a Kiota LB1914? (Not that I'm going to buy one; I'm still shopping...) And how much to aftermarket front 'blowers cost, anyway?
Thanks,
Jim
   / Front snowblowers and Kioti #2
I'm a guy who prefers rear mount blowers, so please bear with my personal bias'. /forums/images/graemlins/smile.gif
Don't know so much about your tractor, does it have a front (aka mid-) pto to hook the blower up to?
Do you have 4 wheel drive?
If yes, then a front blower is great.
If no to both, then they get pretty expensive because you have to run a gearset off the rear pto, a driveline under the tractor to the front, and all the mounting & lifting hardware up front.
And, without front wheel assist, you have all the weight up front, which takes away your snow traction.
--->Paul
Paul, I don't have a tractor yet; I'm still shopping.
The Kioti 1914 DOES have 4WD. This is what the spec sheet says about front PTO. Not sure what it means:
"The engine is equipped with a splined crankshaft for use as a front PTO." /forums/images/graemlins/confused.gif
Thanks,
Jim
   / Front snowblowers and Kioti #4
<font color="blue">The engine is equipped with a splined crankshaft for use as a front PTO." /forums/images/graemlins/confused.gif
</font>
See the shaft coming out of the lower pulley in the picture.
Don
   / Front snowblowers and Kioti #5
That splined shaft is great for running a hyd pump, powering a vbelt, or something. It would take something to use it for a snowblower I think.
Many 'front' ptos are actually coming out of the transmission about in the middle of the tractor, under it. It sticks forward, a splined shaft. Many turn at 1000 rpm, but can be different. It is fairly easy to hook a snow blower up to this, and tractors with a front (mid) pto typically have blowers designed for such use. They have a fairly straightforward mounting system when it's designed from the factory.
If you do not have a front (mid) pto then the driveline to power the snow blower becomes complicated (more $$$$) and the extra mounting brackets & lifts become more combersome & complicated (more $$$$). In addition to the cost, 'more complicated' usually is far more difficult to mount...
At that point, a rear 3 pt snow blower is about 1/2 price, simple to mount/ dismount, and retains it's resale value because anyone can use it, not just your model of tractor.
Guess that's what I would look at.
--->Paul
Paul,
Thanks for that info...very helpful. The problem I see with a rear-mount snowblower is that my driveway's nearly 1000 feet long, and I'm not sure how comfortable I'd be backing up and down it three or four times every time it snows, looking over my shoulder. I've never tried it before; maybe it's fine.
Cheers,
Jim
Don't have one. Still shoppin'.
Jim
   / Front snowblowers and Kioti #9
I have had three JD all with front blowers. Currently I have a JD 4200 with a 59" two stage front blower. The ease which which you can operate a front blower makes it extremely efficient, albeit more costly. I can do my 400 ft of drive and two turn around areas in less than 15 minutes regardless of the depth of snow or what presents the county plows have left me, without getting a sore neck. So far this season I have had 180 inches of snow and the year before last had 192", so I get a lot of practice. /forums/images/graemlins/smile.gif
Bill
   / Front snowblowers and Kioti #10
Front snowblowers are just plain expensive.
I am thinking about buying a snowblower for a power trac tractor. All the usual concerns about a mid mount pto, special spline off the engine, etc become moot points with the power trac.
A 60" snowblower is $3,000 and a 72" is $3,500. Considering that I will already have a dozer blade and fel with ultimate quick attach, I may just say NO to any snowblower.
Yooper Dave
AGT MY50R Mini Excavator (A44501)
AGT MY50R Mini...
2014 Ford Taurus Police Interceptor Sedan (A42744)
2014 Ford Taurus...
INOP/NON-RUNNING 2009 Mack GU813 Truck, VIN # 1M2AX13C09M004546 (A44391)
INOP/NON-RUNNING...
2013 KOMATSU D39EX DOZER (A43003)
2013 KOMATSU D39EX...
1999 Ford F-250 Knapheide Service Truck (A44571)
1999 Ford F-250...
2015 Ford Transit 350HD Cargo Van (A44571)
2015 Ford Transit...
