Front Snow Plow - To hydro or not.
   / Front Snow Plow - To hydro or not. #1
Avery11
Bronze Member
Southern NH
2013 Kubota B2320
Evening,
This season I am contemplating adding a front plow blade to my B2320. I have a rear blade but would like the front option as well.
I want to keep the cost down so I'm searching Craigslist and have come upon many light truck blades which include pusher tubes (is that the right term) and hydraulic cylinders. For a solid blade that I can cut down I'm looking at around $200 and I would fab a bracket to attach to my QA.
I have also looked at the more simple 5' Moose blades which lack the hydraulic option.
Assuming I have decided I want a front blade, should I go with the simple Moose or the light truck model with the potential for hydraulic angling later on. I don't have a third function valve but will likely add one next year for a grapple.
I have a 60 foot paved driveway with a single lane leading to a 3 wide parking area.
Is power angling really that important? Do those who have it use it enough to justify the added cost and complexity?
Thank you for your time.
A.
   / Front Snow Plow - To hydro or not. #2
Yes, you could use your curl / dump function to control a power angle plow. You can easily adapt a manual angle blade to a QA plate and just manually change the angle. Having power angle is not really important unless you don't want to get off the tractor to manually change the blade angle.
For your $200 about all you can do is adapt a manual blade to a QA plate.
I went with PA so I don't have to get out of the nice warm cab. My tractor has rear remotes so I ran a pair of hoses up to the front and use the remote to angle the blade. I have about $600-700 in my plow and that's just for the QA plate, extra steel bracing, hoses, hyd. fittings, relief valve, misc. welding materials and paint. I already had the used truck plow sitting in the yard.
   / Front Snow Plow - To hydro or not. #3
I just bought a 7-1/2' Western Plow for $300. Removed he truck mount and brackets. Welding two pin mounts on the lower edge of a quick disconnect plate and hook on the top for a chain. Loader will raise, lower and tip forward and back. Removed the hydraulic Rams. Western plows have a series of holes in the rotator segment. Will just have to get off the tractor and rotate by hand then insert a lynch pin.
   / Front Snow Plow - To hydro or not. #4
I plow 325' of driveway. And, I have come to realize, that if I plan it right, most of the time, I don't have to change the angle.
Even when, the weather gets real ugly, I only have to change it a few times.
While I would like to have power angle, it's not that big a deal to me at this point.
   / Front Snow Plow - To hydro or not. #5
Not a lot of area to plow so a non-powered blade should work.I plow about 3 miles of drives,parking areas and woods road and couldn't be without power angle.
The Moose plows are designed for lighter weight vehicles but should be o.k. for a "B" series.Make sure the trip springs are working.
   / Front Snow Plow - To hydro or not. #6
While it sounds good to have an angle blade you will soon find out that the more snow you load up front the more you slide sideways.
That is mainly because with a tractor we plow slowly while a truck plows at speed thus flinging the snow.
I say this so that you consider seriously the need for power angling that you would not really use.
Angle plowing with a CUT is probably only valid in minor events like 2" or so (which in reality don't need plowing).
When U have 6-10" events a blower is your friend.
   / Front Snow Plow - To hydro or not. #7
I'm in the power angle camp but I'd suggest looking at a subframe mounted plow if you can do some fabrication. Much much stronger setup than a QA plate on the loader. Plus you can use the loader hydraulics to run all the plow functions.
   / Front Snow Plow - To hydro or not. #8
Given the size and description of your driveway you may find that instead of a power angle plow that more of a box pusher would be better. So a straight plow with box ends. Starting with a manual blade would allow you to go either way eventually. Box pushers are very popular when the snow has to be moved to a specific location (one big pile in a parking lot). I found that even with a 7.5' plow on my truck that box ends would be nice to clear my parking area and also for the main driveway once the banks got big some winters because I just ended up pushing all the snow down to the end where I piled it in my yard. I used my 186d with turfs to move snow with the FEL bucket sometimes and it will push a surprising amount of snow straight ahead. The fact that compacts can get pushed around when angled adds to this advantage. One way to prevent that though is to make sure the plow can flow separate from the loader frame, so the weight of the loader frame remains on the front tires.
   / Front Snow Plow - To hydro or not. #9
I wish you could see what I can do with mine. You would be quite surprised.
I have no problem pushing a 6' loader mounted plow, on a gravel drive, through deep snow, with the plow angled.
I have turf tires, (no chains), 4wd, and I keep the backhoe on for ballast.
The secret, is to not angle the plow all the way. The more you angle, the more sideways, and turning forces you put on the tractor.
Mine works well, angled half way.
I have had both frame, and loader mounted plows. I believe, the loader plow is superior in every way.
A loader mounted plow, would give you the ability to make the first pass at 6-18", if the snow is too deep. (I never have to).
And, you can push the tops off the snow piles, if you need to. My wife drives a civic, so, I have to do that all the time for her to be able to see over them.
Thank you for the advice, Men. I realize this subject has been talked out so I appreciate your input.
I have 2 choices narrowed down:
1) 5' Moose County Plow with a bracket made to mount to a Kubota bucket the same size as mine - $125
2) A 7.5' Fisher Speed Caster with frame, cylinders, lights, pump, and all. $200
Both solid with no need for repair and both prices firm. I would need to fab a pin mount for the Fisher, cut to length, and fit the hydraulics (no TFV so would use dump/curl).
I recently came into a Harris torch with cylinders and Miller Passport Plus but have no time or experience with either so I'm not sure I would be ready for snow with all the other projects I have going.
Anyone think I should grab that Fisher too for a spring project? I'm sure I could get my money back from either setup.
So, I can go with K.I.S.S. or Buy Once, Cry Once and a project, or both.
Decisions...
2004 Toro 74246 Turbo Force 60in Zero Turn Commercial Mower (A50322)
2004 Toro 74246...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
Year: 2018 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 184,501 Plate: Body Type: 4 (A51691)
Year: 2018 Make...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
