front seal on axle below elbow on John deere 3320 repair
   / front seal on axle below elbow on John deere 3320 repair #1
tradesmen4
maine
3320 john deere
Good afternoon has any one replaced the seal that is below the elbow on the front axle. And was it a big job. Thanks for any info you may have. Greg
   / front seal on axle below elbow on John deere 3320 repair #2
Final drive cover can be removed from axle w/out taking anything else apart (well except the wheel obviously). Just take out the bolts from that cover (housing that supports hub shaft and final drive bevel gear). The cover is glued/sealed so probably have to pry off and then make sure you use a good sealant to re-assemble. No special tools should be needed beyond snap ring pliers and since not doing any bearings or other iron you will not have to re-set end play or backlash.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
Genie GTH-644 (A50490)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
