Front remotes
   / Front remotes #1
duckruck
Paradise, Texas
kioti dk55
How hard would it be to diy install front remotes on my dk55. It has rear remotes installed. Need to hook up a grapple without running hoses to the rear.
   / Front remotes #2
This has been asked and answered many times.
There are 3 options: hoses to back: cheap ($150) and easy; electric diverter valve in curl circuit: harder and costs more ($600 and up); and true third function: even harder and costs even more ($900). Cost guesses don't include labor.
   / Front remotes #3
What's the concern over using your rear remotes?
I'm doing that with my NX: I'd spent enough on other stuff (like implements) and couldn't justify any other solution, especially given what I expect my use of this function will be. I'm probably at $350 for my parts: I went Cadillac on everything (high-end hoses; a bunch of disconnects; protective sock on much of the hoses; hose saver etc.). I have three rear remotes, in which case I still have one remote available (have an hydraulic top-link).
   / Front remotes #4
   / Front remotes #5
I'm with sysop - 3rd function will probably be your best bet.
Depending on how fancy you get with your set-up you can build your own anywhere from $500 to $900 estimates here.
EverythingAttachments.com sells the W.R. Long kit for $837 (which is what I used as my comparison base when I estimated my project)
3rd function valve kit for any tractor, free shipping within 1,000 miles!!
I didn't like a couple things about that kit so I ended up building my own from scratch. After subtracting for "lessons learned" in the design process - I'm probably at about the $850-900 mark but I also have things not included in the W.R. Long kit (like hose protectors, mounting blocks, etc) plus I have a system that is exactly what I want and I understand how every bit works because I built it.
http://www.tractorbynet.com/forums/customization/358086-kioti-ck-35-3rd-function.html
In the interest of full disclosure - I wanted/needed a Sub-plate with ports on just 2 sides instead of 1 port per side and (due to the extra material & machining to make that happen) it was pretty costly compared to a standard sub-plate - which again drove the cost of my project higher.
The most expensive components are the valve/solenoid and hoses. Next down is grip & sub-plate, after that it's just misc fittings & hardware (which collectively is really the 2rd highest "item" after valve & hoses if figured together).
Best of luck whatever you decide to do.
   / Front remotes #6
For any DIY approach, I recommend you study and understand the various types of hydraulic fittings. This can be confusing; in addition to different sizes, there are SAE/NPT fittings, English fittings, metric fittings, and Japanese fittings (some in both straight and tapered). A little planning can save you many adapters as well as save space. Several online folks (like Surplus Center, Discount Hydraulic Hoses, and others) have good technical reference material. For example this one from Discount Hydraulic Hoses.
   / Front remotes #7
Most of project time I use my rear remotes at the same time I use the fronts. Not an either or situation. I have a W.R. Long kit on my DK45 installed by the dealer when I purchased the tractor. It has a replacement FEL top handle piece that contains the front remote switch. Works great.
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
20305 (A51694)
20305 (A51694)
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
