case685
Hi Guys,
I am looking for the best way to set up a front pto on my tractor to run a 6ft snowblower. I want to do this mechanically as opposed to hydraulically since my tractor is only 35 pto hp.
I don't have mid pto so my options are: electric clutch( preferred ) or gearbox on the rear pto with a drive shaft running to the front. I think the e-clutch is a good option for me since the main engine pulley on my tractor has a machined face with bolts and there is a "tunnel" thru to the front of the tractor to allow for a driveshaft. After looking on the Ogura website I saw several models of e-clutches that looked like they could work...here are the specs of the 3 I'm looking at: #526115 rated for 150 ft lbs of torque, 1.125" bore, single B groove pulley 5.37" diameter....#523967 rated for 175 ft lbs, 1.125" bore, dual B groove pulley 4" diameter....#528005 rated at 200 ft lbs, 1.4375" bore, triple A groove pulley 4.56" diameter. All 3 are rated to 3600 rpm, there is larger one rated for 250 ft lbs torque but I don't think I need to go that high.
One other thing I'm wondering about....my tractor is 41 engine hp so does that mean by running the clutch off the engine that I would gain 6 hp?
Looking forward to any and all advice and/or opinions on this.
Gerald
Gerald
