front loader joystick issue
   / front loader joystick issue #1
tylerfarm
Kubota L4330
I have a Kubota L4330 that is about 5 years old. With the onset of cold weather I have noticed that the cab needs to warm up considerably before the joystick will move in any direction. This has not happened in the past. Could this be a moisture issue? Hydraulics?
Any thoughts would be appreciated.
Deb
   / front loader joystick issue #2
What happens water gets in the loader valve. Take the caps off on the loader valve there should be 2 allen screws holding them on, they usually face the front on the tractor (only take the caps off if you take the lower spacer off be carefull the are 4 little balls in there)spray a cleaner in there then fill with a waterproof winter grease .My L4200 did the same thing and this fixed it. It doesn't take much moisture to make them freeze up. Hope this helps:thumbsup:
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
16FT flat bed trailer (A53424)
16FT flat bed...
RIGID TOOLBOX (A52472)
CONTACT INFO (A53084)
