Front loader compatibility
   / Front loader compatibility #1
swarley814
Ford 1720
Hello, I have a ford 1720 with a 7108 front end loader. A way nicer new holland 2120 just came up for sale that I would like to buy but was just wondering if my loader will mount right up to that tractor. Thanks
   / Front loader compatibility #2
Hello, I have a ford 1720 with a 7108 front end loader. A way nticer new holland 2120 just came up for sale that I would like to buy but was just wondering if my loader will mount right up to that tractor. Thanks
I don't know. I don't know how many times I made brackets to put a loader on a different tractor. It can be made to fit if it kinda close in size.
That should fit but you'll need to measure. Those are same series. I'd mainly be concerned with rear brackets. Eyeball them. Check width of transmission where rear brackets go. Bolt hole pattern. Plus, you have your old brackets if you need to modify.
   / Front loader compatibility #3
Those two tractors should be the same size. Mainly be concerned with rear mounts. Transmission width. Length should work. All we run is Ford's and I worked at Ford as a mechanic. There's lots of tractors and lots of numbers. I'm thinking those two are close. New Holland didn't change the tractors up, kept them the same.
   / Front loader compatibility #4
The 1720 used the 7108 loader, the 7108 fit the 1320-1920. For the 3 cylinder tractors it used a 9600429 rear bracket, and a 9600438 front bracket. The 4 cylinder 1920 used a 9600682 rear bracket and a 9600675 front bracket. This definitively suggests that the brackets would need to be changed or modified.
below is a link to the parts books.
   / Front loader compatibility #5
I've had a 1710 & a 2120. The 2120 is quite a bit larger,
Andy
2004 Hydraulic Breaker Excavator Attachment (A49461)
2004 Hydraulic...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
