Front end snapped-- bummer
   / Front end snapped-- bummer #1
thebudman
Bad news: I was using the FEL on my 254 Jimna/NorTrac while in 4x4 (ok-- I know its bad to do that, but I was in clay-like mud and thought there'd be enugh wheel slippage). I heard something snap in the front left wheel. Thinking this was bad, I limped it back to the garage in 2wd. However, while en route, the left front wheel locked up. I put in in reverse and managed to get it to move freely, rolled for another 50 yards or so, then it locked up again. Putting it in reverse freed it up and I was able to get it in the garage.
My question now is: what did I break, how complicated is it to fix, and, if we ID the problem, how much will the new part be? Any why did it break in the first place? Any suggestions?
   / Front end snapped-- bummer #2
Ouch, being it locked and released, I'm guessing gear teeth. In our expereince withe Jinma tractors, the differential gears were the ones to go, but it is also possible something in the outer drive went. Sounds like time for some exploritory surgery. If you heard it on one side, I would start there, take the final drive, open it up off and have a look. Before you do, you can check the diff by raising the front end, with 4wd engaged, one wheel should roll backward when the other is turned forward, then when out of thear, hold one wheel stationary while turning the other and see what it feels like, you should be able to feel the broken gears on the bad side or in the diff.
   / Front end snapped-- bummer #3
Chip is right,you will need to figure out what side or what gear is damaged,Once you get it checked out let me know,we have all the parts or depending on how mechanical you are we have assemblies,that are ready to just bolt on
Tommy
   / Front end snapped-- bummer #4
budman,
Did you get to the bottom of the problem yet?
Tommy and Chip have given you a good direction to follow.
I had the same thing happen to me under exactly the same conditions, except on my Kama tractor.
I heard a "crunch" and one of the front wheels lock up. Lucky for me the problem turned out to be in the final drives. Turned out that 2 small bevel gears were stripped, and probably some of the broken teeth got wedged between other gear teeth. My damage, to be specific, was to the bevel gears attached to the front axle shaft, and the vertical one in the front drive casting (the top one, where the 2 gears engage). It turned out to be an easy repair...just scary at first since I had never opened the front drives before.
Even if it is not those bevel gears, Tommy will surely have parts for you.
Here is a link to the repair on the Kama tractor:
Kama 554 Front Drive Repair
The front drives are similar enough and there are lots of photos to help you through.
This link is something I did to repair my wife's 4WD on her Jinma 284:
4WD Repair on Jinma 284
That one shows how I fixed the front drive shaft engagement.
I don't know how the dealers feel about that repair, though? :)
Rob-
   / Front end snapped-- bummer #5
Why do you say it's a bad idea to use the FEL while 4WD is engaged?:confused:
   / Front end snapped-- bummer #6
That comment is really most applicable to the Jinma 4wd 200 series tractors. Bigger Jinmas (300 series and above) - and other Chinese tractor brands in general - don't have that problem. I regularly slammed into dirt/gravel/rock piles with my TS354C in 4wd without issue, except for the ruts I dug into the soil or gravel. That said, I don't think I'd use that particular technique on asphalt or cement.
//greg//
   / Front end snapped-- bummer #7
God's Country,
The reason for not using the loader when in 4WD is that the additional load of a bucket full of wet dirt or rocks or something else pretty heavy puts a high load on the relatively weak front drive components. As Greg noted, the 300 series Jinmas have much heavier front drive assemblies than the 200 series does, but then, they also typically have bigger loader buckets. I'd say it still pays to be cautious.
The front and rear drive systems are lined by the transmission and transfer case and when the loader bucket is heavy the the front wheels now have more traction and the rear wheels have less. Under the wrong circumstances you can load the front wheels so much and simultaneously unload the rears to the point that almost all the engine power is being absorbed by the front drive system and overload it to the point something snaps.
I do use my loader while in 4WD but I am careful not to ram the bucket into immovable objects or to get the tractor into a situation where the front wheels have good traction and the rear wheels can easily slip. So far I haven't had any such problems with my 300-series Jinma, but it only takes a moment's carelessness or ill-considered exuberance to wreck something. You can easily guess how I learned this lesson, right? :)
Rich
   / Front end snapped-- bummer #8
Its obvious from the thread that the front axles are weak. But in general you have smaller tires which require less torque to spin on the Front and the diffs are open so unlike a rear end that when locked up will put all the power to the wheel with traction, this does not happen in the front. Anyways it cant hurt to disengage when using the loader but the benefit of 4x4 is that you do not have to ram the dirt pile, just slightly tilt the bucket while loading to place weight on the front drives and the bucket fill better. To not use 4x4 with a loader when digging in dirt makes little sense. (unless of course you know it will break your tractor)
   / Front end snapped-- bummer #9
I'm sorry to hear that one must be so cautious when loading on these tractors.
   / Front end snapped-- bummer #10
What you say has merit - IF - there was a center differential. I have not by any means seen every Chinese tractor ever made. But those I have seen and worked on do NOT have center differentials. It's a straight mechanical connection, no slip clutches, nothing. So with the 200 Series 4wd Jinma, this issue is no more complicated than an under-built front drive assembly - a problem that can be avoided by not using 4wd during loader operation
There is no admission from the manufacturer on this, and no fix (that I know of) in the works. It's simply a School of Hard Knocks lesson learned by many who actually own and operate a 4wd Jinma 200 Series tractor.
//greg//
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
