Front End Loader Questions
   / Front End Loader Questions #1
hspfour
Montgomery County, TX
What is the largest Hydraulic pump which can be put on a 4020 JD? I currently have an 8 gal/min pump and want to go bigger. Does anyone have any reviews about using a TAS front end loader on a 4020 JD? Also, are there any TAS dealers near Laffayette or Lake Charles, LA?
   / Front End Loader Questions #2
Welcome to the forum, of compact utility tractors. May not be the place that feels comfortable giving you advice on a 'big' tractor.
But, don't give up hope. There are a lot of knowledgable members, and one may just have the answer to your question.
I can't tell what your ideas are for a 'larger' pump. One that is PTO driven and max's out the HP of the 4020 tractor as being the limitation, or a pump that is a replacement of the OEM pump on the 4020 now, but just more gal/min?
If any suggestion, I would say go to your Deere dealer or go to a hydraulic pump manufacturer.
If you can feed us more information, maybe someone will pick up on the thread and help you with a solution. /forums/images/graemlins/wink.gif
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
MQ POWER 25KW GENERATOR (A52472)
MQ POWER 25KW...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
